SOURCE: i knocked over seagate 500 freeagent and it beeped and groaned an
I'm not expert but try freeze therapy. I did it in on mine and it did not work but I hear it does rarely. Basically all you do is wrap the harddrive in a plastic bag tightly to prevent any form of moister entering, leave it in for about two days and plug it back it. It's said that sometimes if the lense is shaken out of place the cold would make the metal go back to original placing. This means you plug the harddrive in while still frozen, just something try before throwing it away or replacing it.
SOURCE: Knocked over Seagate 500GB FA Pro Makes Beep Noise/Can't Connect
it sounds like the disc (inside the hard drive casing) has become jammed or what is known as "stickation". the best way to unstick the disc is usually another sharp blow. the best way to do this is to remove the drive from the external casing and, while holding it by one side, strike the other side downward onto a hard surface like a wood desk. do not strike it on metal or cement as you may cause more damage. make sure the surface is softer than the drive casing. it sounds extreme but it has worked for me on several occasions.
SOURCE: Seagate Freeagent Dropped
Unfortunately what you are describing is a damaged platter inside the hard drive. You may be able to get a technician to recover some data but generally this means the drive is gone forever.
SOURCE: Seagate Freeagent 1.5TB hard drive beeping
have you ever found a solution? i have the same problem with my seagate barracuda 7200.11 1,5TB
SOURCE: seagate is making some kind
You could try the utility program 'Seatools' which is a free download from Seagate website
