The dryer is indicating that the door is open. If you can verify that the door is latched, the latch mechanism or the control board may have been damaged during heating coil replacement.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Sounds like the high limit switch is cooling down, clicks closed then unit will start again. Unplug it, remove the back and check for any obstructions in the vent system or any large build up of lint etc inside the back, in and around the blower etc. Also check the entire length of the vent it could be blocked with lint (very dangerous) should be cleaned at least every 12 months. every 6 if used daily.
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
have you checked the thermo cut off switch at the back it may have got to hot and tripped it. it wold detect that the heater is not on and you would be able to hold the button on but it will just turn ther motor round and thats it.
Check the door switch to see if it "clicks" when you push and release it. If it clicks, then the control board will need to be replaced. Here is the part you will need to order.
