Watches Logo
J
John C Kenneth Posted on Sep 12, 2018
How do I turn off the alarm mode on the Timex Model When the alarm is not needed
My Timex T-231 Has a permanent annoying alarm even when it is not needed if you can solve this problem.Thank you for any help you can give me John Kenneth
3 Related Answers
Anonymous
  • 8 Answers
  • Posted on May 27, 2009
SOURCE: need setting instructions for date,alarm,etc on my timex expedition
http://assets.timex.com/manuals/index.html
Here is the link for all Timex watches and the appropriate manuals.
This should provide you with the information you require, if you have an issue not covered there I will try to find you more specific information.
Anonymous
  • 18 Answers
  • Posted on Mar 05, 2010
SOURCE: Timex Triathlon Alarm Chronograph User Guide
i suggest you reset your watch
Bruce Robin
  • 300 Answers
  • Posted on Apr 15, 2010
SOURCE: my kenneth cole KC2555 watch doesnt give the
If it's more than a year old it may need a fresh battery. Any watch or jewelry shop can do that for you for about $8.
7helpful
Timex expedition wr100m alarm
TURNING OFF A TIMEX IRONMAN (the wr100m is the one I made this work on) ALARM: hold "set" to set each alarm to "on," not "hide." exit. flip through the modes until each alarm shows. don't hit "set," hit "start" or "stop." it should then switch from showing as daily or whatever to showing as OFF! good luck. so, UNHIDE, SHOW ALARM, DON'T SET, STOP -> OFF.
Set date on 1440 sports watch 504-t5k085
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
28helpful
How do I turn off the hourly chime on the Timex 1440?
Use the mode button to toggle to the alarm function. Once at the alarm function, press start/stop. It wil turn the alarm on or off as well as the hourly chime.
1helpful
2answers
Can't turn off chime on timex ironman watch
Go to the timex website, scroll to bottom, click on Product Manuals and Downloads. Then at the bottom of next page, find your watch by model number and look up how to control chime in instructions. It is usually something in the alarm menu... in my case, hitting stop/reset in alarm mode toggles the chimes.
http://assets.timex.com/user_guides/W9_M814/W9_M814_AllLanguages.pdf
Need to turn off alarm
A model would be most helpful here. Timex has a couple different alarm set ups.
With most of their watch if you cycle through the modes using the mode button you will come to alarm. Depress set and the alarm will toggle on or off.
With Dial alarm models you simply depress the alarm button (the one with the red stripe).
How can i set digital time and alarm in the Timex wrist watch model is- MF13-Y-S7
Try this ,it may work for you as i m having mf13-t1
Press MODE then then SET
Press ALARM to increase the count and to change time t1 or t2.
Press MODE to switch the digit place
finally press SET and then MODE
Note: Check for bell and sound symbols,if they are not there
Press MODE then then SET again press SET
Press ALARM for once or twice depending on symbols.
I have a Timex 1440 sports watch. I have Parkinsons and must take medicine on a specific timed schedule. For a while all was well with this watch; the alarm rang when set. However, I think I inadvertently...
I think you just turned off the alarm. You need to press the MODE button until you are in the alarm mode. (AL or ALARM on screen), then I believe that you just need to click on the upper right hand button (strat/split or stop/reset) repeatedly until the alarm goes back on. Hope this helps.
7helpful
Dont know how to turn on hourly chime timex atlantis 100
Set chime and Alarm on or off
Press MODE to select ALARM
Press START/SPLIT to change (clock sign and chime sign will appear and disappear as you keep on pressing).
Press MODE again and you are all set.
1helpful
Old model timex compact disc digital audio
Hi catlady05,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
