SOURCE: Makita drop saw is very tight when dropping
I assume when you say drop saw you mean miter box. The bearing and spring are direct targets for debris that is not discharged through the discharge part near the top of saw. Usually sawdust , sap and general dirt can get the hinge/bearing/spring all clogged up. Clean it as best you can with an old toothbrush and then spray with a good quality liquid grease available at a hardware store or Lowes.
SOURCE: Where do u as oil in makita 1500 jackhammer?
Go to http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in search box in the top right. Two models of the HM1500 will come up, select yours and open the owner's manual. Find the paragraph labeled 'Lubrication' and follow it precicely. Demo hammers are very picky about what type of grease they use and how much. Too thick and they won't work, too thin and they won't lubricate properly and the parts inside are very expensive to replace. Same applies to how much to use.
SOURCE: just bought a new makita jackhammer what is the
I need to check the oil on my machine.. help please
SOURCE: I want to know about the wires connect a jackhammer Makita 1 500
Makita Authorized Factory Service Centers
Fill in search box with model # and you can download a service manual and parts breakdown list
