SOURCE: Chefmate RS-06DR mini Fridge (1.6 Cubic Feet)
My chefmate is **** because the internal fan is garbage, its cheap, it
doesn't work or give enough flow, try a higher flow unit. You can get
the 12v at tigerdirect.com with some high flow (AND LIGHTS :) ) for a
few bucks to save your 100 dollar investment. The removal of the orig
fan is easy. The evap is a good setup, but the cooling setup for it
seems to be sh*t. Cheap fans = cheap setup and this is why everyone
hates these units cause it can't pump the goods.
For the record my fan died, so my evap and fan froze over completely
and spoiled my food and burned out the fan completely and probably
helped to short it. I can get it going if I flicker the fan with my
finger but she is dead and can't catch naturally. You could replace the
chefmate fan with most computer fans too... fyi if you got a junk tower
laying around.
While your at it clean the fans on the back and take off the back panel
which kicks out the hot air from the hot flow. It helps if your unit is
older (a year plus+ in a dorm is like 4 in a clean house lol)
SOURCE: What size is this fridge?
there is a sticker some where inside that will tell you cubic feet
SOURCE: How many cubic feet is this freezer
After looking over their website, which is not very helpful, it appears that it would be approximately 5.0 to 5.2 cubic feet. It seems that in most cases, the model number contains the size. Check it out at Danby.com
Hope this helps.
SOURCE: How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
SOURCE: how many cubic feet is a GE spacemaker model l# JVM240WL001
you must ask some vendor Online via chat with GE, they offer many Sales, and good opportunity. Get in tourch with them.
God bless you
