When you are unable to power on your Vodafone Smart First 7 VFD 200 phone hard reset recovery tutorial
This is a simple step by step instructional article to help guide you through the steps of doing a hard reset on your VFD 200 Android phone.
If your phone crashes, reboots, freeze, or cannot be powered on Some third-party software is not compatible with your phone. Reset the phone to factory status. Uninstall the software that may cause the problem or upgrade the phone software.
Turn off the phone.
Press and hold the Volume DOWN and POWER ON the phone until the phone turns on, the screen lights up.
Keep holding the POWER and press shortly the Volume UP and then shortly the VOLUME DOWN.
Now the recovery menu will come up.
Use the volume key and navigate to Wipe data / Factory reset and press POWER to confirm the highlighted selection.
Navigate to yes -- delete all user data and confirm the data deletion.
Wait until the hard reset operation ends and the phone reboots.
Note: After this procedure the first boot may take a little longer than usual. Be patient.
When you first power on your phone after reset it to factory settings (in Backup & reset menu option), you need to finish some basic settings before using it.
Flick the language field to select the language. Then foll
