SOURCE: new chain for 16'' 35 cc mcculloch
You need one of these chains or something similar:
Oregon 16-Inch Pro-Guard Chain Saw Chain Fits Cub Cadet, Echo, Homelite, McCulloch, Makita, Partner, Poulan #H66
SOURCE: I need a manual for a McCulloch Timber Bear Model#60013414 chains
hi,
i believe this is the manual you are needing it is on ebay
Item number: 150322102913
good luck.
SOURCE: how to remove clutch. McCulloch 438 chainsaw.
I think its an outboard clutch, use this as a guide. A YouTube video shows the procedure using a Husqvarna 350 here:
http://www.youtube.com/watch?v=cdqkIuVNUQc
1. I cannot find an IPL for your saw, it may require special tools.
2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and be cut when the piston rises.
3. It is probably a left handed thread (tighten it to loosen it).
Let us know how it worked for you. GL
Lou
