I wanted to reserve IP for my printer but no way to edit mistakes made in it, and I get conflicts when I try to add a new one with same IP and MAC address. I should be able to either edit the previous item or delete it permanently and add a new one, no? I would hope that I do not have to go all way back to factory recent, especially when the Shaw tich had originally set it up.
Wow a very very hard to understand question there(but par)
is this 3482 the only thing you have there? (LAN WISE)
it is a modem,/router box this thing,+wifi
it setup page told in the free manual is
http://192.168.0.1
wow does the printer connect, (ethernet or wifi)?????
The setup page is all you need. to set the printer on a fixed IP
wired is best. wifi is more tedious ask, if true. wifi.
fixed means MAC is IP frozen by you so if power is lost to ALL
the printer still works later( power AC restored)
https://www.cleancss.com/user-manuals/UID/TG3482ER3
see trusted MAC to, page.
see finding IP or MAC pages the reserve it there, fixed.
the save that
and last run and load he printer makers application software
and it finds the printer easy if only one printer there.
no printer told so can NOT wax smarter or clearer.
SOURCE: Setting IP Address
I finally got the unit to work. I reset the unit a couple times to factory default. arp -s command for the ip address, set up the port in my windowsxp for the set ip. Shut everything down and started it back and it worked. Thanks for the help
SOURCE: Copier won't print - IP address was switched?
That is your issue. If you allow it to set up using DHCP it will drop off often.
You need to set static IP addresses for the router and machine.
You have to have matching IP addresses, Gateways for it to communicate properly.
Set them permanently.
SOURCE: Reset Dell 1720dn network address to get back access to it?
Please have a look if you have Dell 1700 series laser printer. Please follow the instruction bellow to reset printer to factory default: 1. Power Off the Printer from the back switch from the back 2. Open Front cover 3. Hold Down “Continue” & “Cancel” button while turning printer on
se http://digg.com/hardware/How_to_Reset_Dell_1700_1700dn_1710_1710dn_1720_1720
Regards Anders.Thornberg.Qnetcom.se
SOURCE: HP LASERJET 3055 Manual IP Address not saving
Switch off the printer and press * & enter key together &switch on wait till you see " permanent storage int"
then release button your printer comes back to original defaults
then re-configure printer as you require
Murali,
PALLAVI INFOTECH
BANGALORE
SOURCE: Recently I subscribed ATT DSL Service conflict IP Address
the motorola modem that att is using uses 192.168.1.x subnet. log onto your router and change it to 192.168.b.x where b is any number between 2 and 254 (just not 1). You should also log onto the modem and change the setting that allows it to share the external ip address with the router. You will need to do this if you plan on accessing your network from the internet.
