The onn cannot be connected to the Emerson wirelessly.
If it is connected to the Emerson TV, there has to be a wire plugged in to the audio output on the TV and the left and right input connectors on the sound bar. I have heard that you will only get about as much sound from the sound bar as the TV.
You cannot use the digital audio outputs.
SOURCE: RCR460 with Emerson Tv doesnt change channel to input sources
found the answer but it doesnt help.......i got the number to who makes RCA remote controls and called them and talked to tech support to see what i could do for this problem. According to them, some universal remotes are compatible with most tvs but sometimes the remote can only give you the basic functions (chan up/down, volume up/down, #'s, mute an so on.) i dont really understand why it wouldnt work for the input channel but i do know i have a lower end and low priced tv. so....just like everything else the more you pay...the better it is. I checked the remote on my other tv in the living room and everything works just fine, even the input button. Hope this helps...
SOURCE: cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
SOURCE: best antenna for an old Emerson TV
One major problem with digital broadcasting is that signal strength is an issue. It is entirely possible that people who live far enough away from the stations, or where there are many hills or other obstructions, may find they get few or even no channels. (It's one of the reasons there's been so much confusion and upset over the shift to digital. Some people are just going to be out of luck; the government knows it but they just pretty much say "Too bad.")
If you are using an indoor antenna, like the old rabbit ears that may have worked okay with analog, you should try a new amplified antenna made for the digital signals. You might find it necessary to install an outside antenna. If you already have an outside antenna but it's the same one you've had up for years, you should replace it. It's probably corroded, the cable from it won't be the best for the digital frequencies, and it may not be pointing in the right direction.
There are many antennas to choose from. I know of several people who have purchased antennas online from antennasdirect.com and have been quite happy. You might try talking to others in your area who may already have figured out what works well, and use the same antenna as they have.
SOURCE: emerson tv with no remote will not go to aux channel
Need the remote to go to the aux. The number for parts and service is on the back
