Question about Bunn Coffee Makers & Espresso Machines
I have a Bunn CWTF TWIN coffee machine.....the one side will not stop pouring water out of it....was wondering if there is a replacement part or parts to fix the problem
    New Friend:
Hi, that is a sticking fill solenoid. You can attempt to clean it out but my be better off replacing it. Easily accessible by removing the front cover from the machine. Located in lower front
Posted on May 01, 2019
    Habit-Forming:
    New Friend:
  • 76 Answers
The water inlet valve may be stuck open from mineral deposits. You can get rebuild kits for the older ones or just replace the valve?
Posted on Apr 27, 2019
SOURCE:
Buffalo12980
  • 625 Answers
SOURCE: coffeemaker
The Bunn coffee machine has an internal tank used for holding approx three potfulls of water at just below brewing temperature. When you add water for a potful, the thermostat senses cold water and starts the brew heater. The water level inside the tank comes up and goes through the sprayhead. This "surge" of water, that you call drips is normal. The hot water stratifies to the top of the tank, just like an electric water tank in a house. The internal pot heater kicks in and boils the water already in the tank, raising the water level in the siphon pipe to the sprayhead until the reservoir under the add water opening is empty.
Posted on Sep 15, 2007
  • 60 Answers
SOURCE: my bunn coffee maker CWTF-15 21604-0001
It sound like you are either missing the sprayhead or the temperature isn't hot enough. Check first to see if the sprayhead is there. It fits under the brew basket and looks like a little shower head - it's round and has usually five or six little holes in it. If it is missing your coffee will be weak due to the water not being spread across all of the grounds evenly.
The other thing to check is the temperature. Depending upon where you live the water should be between 185F - 200F. If the water is below that temperature the coffee may look like tea.
Posted on Feb 01, 2008
Coldcut
  • 1554 Answers
SOURCE: When we pour water into
there is an overfill tube in the rear that may be leaking.
Posted on Apr 02, 2008
SOURCE: MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Posted on Mar 16, 2009
SOURCE: water wont come out of my bunn coffee maker
The first pot of water you put in the coffee maker just fills the water tank which is then heated up , once it gets to temperature you then pour second pot of water this pushes the hot water out of the tank through the coffee grounds into the waiting pot. This way you can make coffee faster than a regular coffee maker.
Posted on Jul 19, 2009
I have a bunn cwtf twin,I put new ready lights on both side work for about a week and the they wont light up. and the side the the faucet only brews warm coffee. but the other side does find. HELP
The green ready lights do not last that long. We never replace them on units we service. They are cheaply made. Each side of this coffee maker has its own thermostat. Check to make sure the thermostat is on all the way. If it is check the voltage on the warm side. Make sure it is in the 208v area. This warm problem is 85% the thermostat not set right and or needs replacing.
Apr 28, 2014 | Bunn CWTF Twin TC Coffee Maker
My Bunn CWTF-DV-3Tisleaking water from the top right corner of my machine,and has just started leaking at the base of where the bottom burner is. Could you please help,as we have no technicians were we...
open the top. there is a trough drain that gets limed up. using a phillips head screwdriver, push through and twist, thereby removing the lime and ensuring proper flow. if water can't get through, it may overflow over the sides of the trough. also look behind the trough to the top of the tank and see if there is any water damage around the seals. if there is, replace the seals
Feb 17, 2014 | Bunn CWTF 15-3 Coffee Maker
Water not coming out of hot water spigot
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Dec 10, 2013 | Bunn CWTF 15-APS Coffee Maker
I need to ship a 3 burner BUNN CWTF 15-3. How do I drain the water out?
You can take the lid off and unscrew the nut that holds the water tray. Then take a 3/8 hose to siphon the water out of the machine.
Apr 17, 2013 | Bunn CWTF 15-3 Coffee Maker
Model cwtf-mv water does not turn off , press start to make coffee and water goes in but does not stop
First remove the front panel and there will be instructions fro reprogramming the brewer. If you have done this and it still does not work, then there is a problem with the control board.
Mar 01, 2011 | Bunn CWTF-MV Coffee Maker
What size breaker do I need to install a CWTF - Twin 4/2? I have 208 volts available. Wattage is 6850.
A 50 amp breaker would be best. To find proper amperage its Watts divided by volts, then multiplied by 1.25 for draw.
Jul 16, 2010 | Bunn CWTF Twin-TC (23400.0047) 12-Cup...
Installation of grommet on model cwtf 15 ( 1 lwr/2 upr pf
Which grommet, there are several on the bunn models, but the most commonly replaced one is the one for the P. stat. Remove the top panel there are 2 screws one in front and one in back, then lift the top 2 burners off machine that will give you access to the tank.
Apr 30, 2010 | Bunn CWTF 15-2 (1 Top Warmer) Coffee Maker
Leak from hot water faucet
Replace the water faucet. Contact the company the unit was sold or installed by. they should have the part in stock.
Dec 14, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
Coffee Makers & Espresso Machines Logo
98 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
