SOURCE: Hi, have lost the manual for my treadmill York
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
SOURCE: the treadmill starts then after a few seconds it
More likely LS= Loss Signal open the motor shroud on the motor their should be a cylindrical shape sensor (magnetic). Plug in treadmill and on the motor control board their should be a L E D (red or amber) by manually rotating the motor you should see that light flicker if it does sensor is good if not replace sensor. Next thing if sensor is good check motor brushes to see if they are mis-align or worn if worn less than 3/8" in length replace them
SOURCE: I have a York z16
LS or L5 error is the speed sensor. Because it is such a vague code I can't just tell you exactly what's wrong with it. I can tell you what it may be.
If you are lucky it's just a fuse. If you have belt movement, it's likely that its just a fuse. If there is no belt movement, it can be a computer failure. the MCB will need replacing.
If you have belt movement and you check the fuse, and its not blown, then the speed sensor is no good and needs replacement.
In most cases its a fuse.
Good luck, hope this helps!
SOURCE: I have a York T710 Platinum series treadmill and
hi , i have most manuals what is it you need to know
please email me on [email protected]
and i can send you the manual
Kind Regards
Joe
