Check out this link. Chances are one of the pieces to the valve or the valve is broken. https://www.walmart.com/ip/Thetford-42036-White-Seat-and-Cover-Assembly-for-Style-Lite-and-Plus-Toilets/50279397?wmlspartner=wlpa&selectedSellerId=0&adid=22
SOURCE: Flushing knob on a C2 Theford cassette porta potti hard to turn
Hi! Spray blade which closes holding tank with silicone spray. Make sure spray goes under lip of sealing ring. Also spray around holding tank actuator knob allowing to penetrate underneath to shaft. Don't use a silicone grease as this will gum up the works. If you can't get hold of a light silicone spray try using household type silicone polish intended for furniture. Wipe off any surplus as only thin film required.
John Long
SOURCE: im trying to find the wiring am for a thetford C2
Go to www.thetford.com.
Click Customer Support then Product manuals and download manual in PDF format.
Wiring of C2 has fuse, safety switch, flush switch and flush pump in series. If fuse is blown you probably need to replace pump. Instructions come with replacement pump.
