Is it possible to connect a GE wireless mouse to a logictech nano?
SOURCE: connecting cordless optical logictech mouse
You should install all the necessary drivers! then it will work! moreover you should give your Mouse model so we can assist you further!
SOURCE: GE Wireless Mini Mouse 97985
Press the link button on the receiver the indicator light should start blinking. Then within two seconds press the link button on the bottom of the mouse, the indicator light should quit blinking. After re-linking the devices move the mouse to see if it moves the cursor. If the cursor does not move, then move the mouse and see if the indicator light on the receiver blinks. If the device does not blink then try re-linking the devices again.
SOURCE: how do i open the battery compartment on ge
The mouse requires 2 AAA batteries.
The piece
of plastic on both sides of the embedded dongle, where your palm would
rest on the mouse, is the compartment for the batteries. You need to
slide the piece of plastic away from the direction of the mouse
buttons. You will then be able to put the batteries inside and slip the
piece of plastic back on.
SOURCE: I have a new GE Ergonomic Wireless Mini Mouse -
Be sure to push the connect button on the mouse and squeeze the button on the part that plugs into your USB port.
SOURCE: lost connection between mouse and receiver not
The set point program that came with the mouse should have an option to allow you to reconnect the mouse.
Try opening up setpoint and seeing if the option is there for you.
