Watches Logo
How do I watch sixty minutes on 9 - Watches
How do I reset my radio controlled watch?
set synch options to auto.
May 10, 2015 • Watches
3helpful
2answers
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
6helpful
I'm trying to set my son's Timex 1440 watch. I can get the minutes blinking but when I touch the top right button it only moves the minutes in 30-minute increments. So i can set it at 8:30 or 9:00, for...
I had the same problem with the watch my wife bought me. On the mode make sure it doesn;t say T2 in the top right hand corner. if it does you are in the wrong mode. Hit the mode button until it shows the day of the week highlighted and a date and then go through the normal time set procedures. That worked for me.
My eco drive watch just stopped working... oddly enough it was a day after a day in the sun? It was fine and then I changed the time 1 hour foward and the next day nothing.
Perhaps it got too hot. The operating range for watches seems to be zero to sixty degree centigrade.
If left in a very sunny position it could have exceeded the higher temperature. If it doesn't recover by itself, then try a new battery.
It might be instructive to talk to the maker (address at Citizen.com) to confirm my suggestion before replacing the battery.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
