SOURCE: error 5 error LU1812 live update error
Download and run the LiveUpdate fix tool from Symantec HERE
After you run the fix tool, open Norton 360, click on the "Scans" link
at the top of the window, choose "Comprehensive Scan" and then click
the "Go" button This will take some time, but will thoroughly inspect
your computer for infections
To address your other question regarding the LiveUpdate settings, you
can change the configuration to use an HTTP proxy. To do so, please
follow these steps.
1. Open the "Symantec LiveUpdate" Control Panel.
2. In the LiveUpdate Configuration window, click on the "HTTP" tab.
3. Click on the radio button that says "I want to customize my HTTP
settings for LiveUpdate." Enter the information for your HTTP Proxy
server, click the "Apply" button, and then click the "OK" button.
Please let me know if this process resolves the issue you are having
with LiveUpdate. Also, if the scan finds any infections, please let me
know what is found.
SOURCE: My OS Windows 7 can not Update
The problem might be becoz of service pack of windows 7. Please uninstall the currently installed service-pack and then try to update Windows 7.
Its highly advisable to clean system registery using any good system registery tool like cCleaner.
Please call me for further clarification.
Zulfikar Ali
09899780221
[email protected]
SOURCE: i keep getting error code 0x80080005 when trying
Broadly speaking, you can try one or all of these :
Run CCleaner to clear up PC Junk. Reboot. If you are using windowsupdate try using microsoftupdates and vice versa.
If you still cannot Update Windows Vista (orWinXP/SP2) using windowsupdate, try this :
Open Internet Explorer > Tools >Internet Options > Security > Click 'trusted
sites' icon >Click Sites > uncheck 'require server verification'
Then add following sites :
http://*.windowsupdate.microsoft.com
http://*.windowsupdate.com.
Click Close > Apply > OK. This is known to help the GenuineValidated Windows, in some cases, but not always.
Else, lastly, note your error code and visit this excellent Microsoft Resource : http://support.microsoft.com/default.aspx/ph/6527/
Search for the solution against your error Code.
SOURCE: For Singer Futura CE 250. New laptop with windows 7?
Update with WIndow 7 support is already available at:
http://www.futura-support.com/downloads/ce150.html
If you applied wrong patches you will have to uninstall Futura, reboot, install from the beginning the basic version and then apply an update 3.0.0.9
SOURCE: Error "msi_check: 0x80280002" ,
Error "msi_check: 0x80280002 i tried installing windows live messenger
