Jan de Haan Posted on Sep 10, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wat bekent het knipperen van de oranje/rode verlichting Sony batterij VMHX10?
Lampdeng.com
Level 2:
Renaissance:
An user who is expert in 3 categories / brands.
  • Expert 789 Answers
  • Posted on May 31, 2019
Lampdeng.com
Expert
Level 2:
Renaissance:
Answers
789
Questions
0
Helped
197806
Points
977
The power indicator is off.
two reason:
1,the mainboard is fault
2,the powersupply is fault
I am an expert of repairing projectors for 19 years.
It is my pleasure to receive the message form you,
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
5 Related Answers
Anonymous
  • 770 Answers
  • Posted on Apr 07, 2008
SOURCE: machine wil niet starten
I understand your problem but need the make and Model # to help you with the programming problem
Anonymous
  • 98 Answers
  • Posted on Apr 15, 2009
SOURCE: Lens van mijn Ricoh Caplio R 6 gaat niet meer in of uit
Hoi Van de caplio R6 zijn geen onderdelen leverbaar, de camer moet worden aangeboden aan Ricoh Nederland ze zullen je een website aangeven waar je de gegevens kunt opzetten en daarna pas de camera kan opsturen aan hun servicecenter
Groet,
Rob Rotronica
Anonymous
  • 10406 Answers
  • Posted on Apr 25, 2009
SOURCE: PC Battery voor een Dell 4600
When I boot I get an error message - and I think the battery is to be replaced, what and how should I do?
Thanks in advance for the answer! 1. Turn the computer off. 2. Disconnect the power-cable. 3. Remove the side-panel. 4. Look on the motherboard for a silver-coloured circular piece, about 2 cm. in diameter. 5. Read the lettering on the top of the piece. 6. VERY CAREFULLY remove the piece, by lifting from one edge. 7. Take it to a computer-store, and buy a replacement. 8. Check the lettering on the top of the new piece. 9. Insert the new piece, with the lettering on the new piece matching the lettering in #5, above. 10. Replace the side-panel. 11. Reconnect the power-cable. 12. Start your computer. 13. Immediately, press DEL to enter BIOS-setup. Set the date & time. 14. Save/Exit from BIOS-setup. 15. Reboot.
Joe H.
  • 330 Answers
  • Posted on Apr 05, 2010
SOURCE: verlichting kilometer en toerenteller
esut mir lied, nicht verstein zei doich.Bitte en english.
Anonymous
  • Posted on Nov 03, 2010
SOURCE: hallo, beide rode lichten knipperen bij
You can use SSC Service Utility to reset the counters yourself.
Download this prog.
http://www.ssclg.com/epsone.shtml
This is what your local pc shop will probably use ... it's freeware and works wonders !
Reset de counter en de waste bin.
Na het verwisselen van de batterijen van een rookmelder van de Rokonet Wisdom, blijft het sabotage alarm van kracht. Bij het afmelden wordt er een random code gegeven, waarna opnieuw een code moet worden...
Ik ben niet bekend met dat specifieke alarmsysteem maar ze werken allemaal redelijk vergelijkbaar. Na de invoering van de nieuwe batterij als de problemen brandt proberen te nemen van de rookmelder, verwijder het beslag, activeert de rookmelder door op de knop of het zetten van een magneet op het opnieuw installeren van de batterij (dit zal de rook te wissen) en zorg ervoor dat de rookmelder correct is gemonteerd op de basis. Als het indrukken van de code en uit of uit een paar keer niet werkt, zorg ervoor dat uw systeem is op test met de bewaking bedrijf en eigenlijk op weg van de rookmelder door op de testknop of zetten een magneet tot het. Nadat het alarm is afgegaan ontwapenen met uw code en kijk of het probleem is verdwenen. Als geen tijd om de rookmelder te vervangen. *** Ik gebruikte Google Translate om deze vraag ik hoop dat u begrijpt beantwoorden ***
2answers
Fit my Acer Aspire 3000 ?
akku Acer Aspire 3000 100 percent compatible with you Compaq Presario CQ61. I bought two Acer Aspire 3000 batteries from http://www.pcakkus.com/acer-aspire-3000.html two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
1helpful
Mij telefoon is uitgegaan en wil hem weer aanzetten maar de pincode is onjuist, heb nog 1 mogelijkheid. Ik heb geen gebruiksaanwijzing meer (heb telefoon van dochter gekregen en heb alleen het doosje...
niet nog een keer proberen, gewoon uitzetten, batterij eruit en opnieuw proberen nadat de dochter gebeld is.
dan gewon opnieuw opstarten en correcte pin ingeven.
anders de gsm gewoon met n ander (eigen) sim-kaartje opstarten met eigen pin-code.
ihg. dat de gsm centraal geblokeerd is de PUK code gebruiken, die als het goed is in het doosje van de telefoon hoort te zitten
mazzel
Ganimidis
Camera schakeld na inschakelen direct weer uit
de kodak camera's staan bekend om het hoge stroom verbruik, zeker tijdens het uitschuiven van de lens tijdens het opstarten.
Als de batterij niet vol genoeg is kan de camera zich hierdoor weer uitschakelen.
Ook komt het voor dat de batterij versleten raakt waardoor deze niet genoeg stroom kan leveren.
Een andere (minder vaak voorkomende) oorzaak is dat de lens niet kan uitschuiven door ophoping van vuil of een defect aan het mechanisme hiervoor verantwoordelijk.
2helpful
Waste ink near full
I'm having the same problem. Lots of solution for resetting the printer, but none of them helping me to lead me to the absorber itself inside the printer. It seems to be a lot of work and disassembling half of the printer! Looking on internet I haven't found any answer yet.
As I am living in The Nehterlands I'm looking for solutions in Dutch. One solutions discribes disassembling another Canon printer. This could possibly help. I'll paste the text below. It's dutch, so you'll have to translate it.
Wishing you succes with this matter!
Dutch text:
Wat te doen bij de melding 'Afvalinkt bijna vol'?
Onderstaand verhaal geldt voor de Canon SmartBase MPC200; voor andere Canon
printers geldt ongeveer hetzelfde, met uitzondering van de reset-procedure (zie
hieronder).
Oorzaak
Onderin de printer bevindt zich een langwerpig, dik vloeiblad (een soort spons van
vilt). De overtollige inkt, bijv. de inkt die gebruikt wordt bij het reinigen van de
koppen, wordt afgevoerd naar deze spons. Als deze spons bijna verzadigd is,
verschijnt bovenstaande melding. Dat is ook nodig, want als je gewoon door zou
kunnen gaan, zou de spons geen inkt meer opnemen, en op een bepaald moment zou
je merken, dat de printer zou gaan 'lekken'. Geloof me, dat wil je niet meemaken.
Printerinkt is gemeen spul!
Canon
Het lastige is alleen, dat Canon nogal moeilijk doet over deze melding. Zij hebben
maar één oplossing: opsturen en het probleem door hen laten verhelpen. Kosten: ruim
€ 100,-!!! Toen ik dat van de telefonische helpdesk hoorde, reageerde ik met: "Dan
kan ik beter een nieuwe printer kopen!" De telefoniste was dat eigenlijk wel met mee
eens.
Zoeken
Vervolgens ben ik gaan zoeken op het internet. Wat je daar niet kunt vinden, bestaat
niet, tenslotte... Toen merkte ik al snel dat ik niet de enige was met dit probleem.
Iedere eigenaar van een Canon-printer krijgt er na verloop van tijd mee te maken.
Helaas was er geen kant-en-klare oplossing voor mijn printer, maar door de
beschrijving bij andere printers kreeg ik wel een idee over de oorzaak van het
probleem en wat ik eraan zou kunnen doen.
Oplossing
Over de oorzaak heb ik al geschreven. Over de oplossing gaat het nu. Die gaat in twee
stappen:
1. De vilten spons schoonmaken.
2. De printer resetten.
Dit is een vies werkje. Doe een schort om en gebruik huishoudhandschoenen! Inkt in
je kleren gaat er niet meer uit en op je handen duurt het een hele tijd!
De spons ligt helemaal op de bodemplaat onderin de printer. Je moet dus een beetje
handigheid hebben en niet bang zijn om een schroevendraaier te gebruiken.
Schroef eerst de beide zijkanten van de printer los. Die zitten elk met twee schroeven
vast (één aan de voorkant en één aan de achterkant).
Verwijder dan het toppaneel (met de scanplaat). Die zit vast met twee schroeven aan
de achterkant en drie aan de voorkant (deze drie zitten aan de onderkant van het
bedieningspaneel). Let op: zodra je het toppaneel verwijdert, merk je dat die op drie
plekken vastzit. Op één plek met een schroef (gewoon losdraaien) en op twee plekken
aan de elektronica. Trek die twee punten voorzichtig los. Je kunt het toppaneel nu
opzij leggen.
Dan moet je de printplaat verwijderen. Maak eerst alle 'draden' voorzichtig los. Kijk
goed hoe het vast zat, om het later weer te kunnen bevestigen. Maak dan de printplaat
los (4 schroeven). Verwijder daarna ook de metalen plaat, waarop de printplaat vast
zat.
Je bent er nu bijna. Het bovenste deel van de kast (voor zover die er nu nog staat) is
op de vier hoeken met schroeven bevestigd op het onderste deel van de kast. Je moet
misschien wel even zoeken, want ze zitten diep weggezakt. Schroef ze los.
De bovenkant en de onderkant zijn nu los van elkaar, maar nog wel met draden en
elektronica aan elkaar verbonden. Maak die verbinding niet los, dat is niet nodig.
Doe nu het schort om en de handschoenen aan!!
Je kunt nu bij de bodem van de kast komen. Daar zie je de spons, die zwart is van de
afvalinkt. Kijk eerst hoe de spons erin zit, voordat je die eruit haalt.
Maak de spons voorzichtig schoon. Niet wringen en zo, alleen uitspoelen en eventueel
induwen om de inkt en het water eruit te halen. Ga een flinke poos door, totdat er
alleen nog schoon water uit de spons komt.
Hang de spons een paar uur te drogen in de zon. Gebruik daarna een föhn om ook het
laatste beetje vocht eruit te halen, zodat de spons weer kurkdroog op zijn plek gelegd
kan worden.
Zet de zaak nu weer in elkaar. (Als je het net zo doet als ik, houd je twee schroefjes
over, maar mijn printer doet het nog steeds prima. )
1a. Niet schoonmaken maar bestellen...
Sinds kort weet ik dat je de spons ook kunt bestellen. Dat scheelt een boel pruts- en
schoonmaakwerk.
Je kunt de vilten spons, die uit 2 onderdelen bestaat, bestellen bij ETB (Electronic
Trading Benelux).
Bel naar 0165-850500 en bestel de volgende artikelen:
HC1-0795-000
QA4-0213-000
Toen ik ze bestelde (in maart 2006) waren de kosten voor deze 2 onderdelen samen
maar E 1,04!!
Deze prijs was wel exclusief btw en verzendkosten. Maar omdat ik het samen met
andere producten bestelde, had ik daar geen last van.
Als je nu de printer weer aanzet, kun je merken hoe dom het apparaat is. Hij heeft niet
in de gaten dat de spons weer schoon en leeg is. Dat moet hem nog verteld worden.
Op het internet kon ik daar geen geschikte procedure voor vinden, dus ben ik maar zo
brutaal geweest om Canon op te bellen. Eerst deden ze afwerend (ik moest de printer
opsturen), maar toen ik vertelde, dat ik het grootste deel van het werk zelf al gedaan
had, kreeg ik een technicus aan de lijn, die me stapsgewijs uitlegde wat ik moest doen.
De stappen laat ik hieronder volgen:
1. Zet de printer aan
2. Druk op de (langwerpige) menuknop
3. Druk op de meest linkse ronde knop (Copy)
4. Druk op de ronde knop rechts daarvan (Scan)
5. Druk twee keer op de meest linkse ronde knop (Copy)
6. Druk op het min-symbool (links van OK); het scherm zegt nu: 'Test mode'
7. Druk op OK
8. Blader met het plus-symbool (rechts van OK) tot het scherm zegt: '#8 Printer
Test'.
9. Druk op OK
10. In het scherm staat nu: '8: Printer Test' en daaronder: '- 8 - 2 +'
11. Druk 1x op het plus-symbool; in het scherm staat dan: '- 8 - 3 +'
12. Druk op OK
13. In het scherm staat nu: '[0]: Ink Count'
14. Druk op OK
15. Druk op de knipperende oranje knop om die uit te laten gaan.
16. Mogelijk werkt dat niet. Trek dan de stekker uit het stopcontact.
17. Wacht even. Doe de printer weer aan.
18. Als het goed is, ben je nu bevrijd van de irritante melding over afvalinkt.
Succes!!
Goede middag, Heb IK EEN Epson Stylus C46 Beide lampjes bovenop blijven knipperen om en om, Krijg ookGeen papier toevoer Wat Moet IK DOEN?? mvr. lips
Hallo,
Er is een online handleiding voor de C46 met de volgende link voor
internet explorer:
http://support.epson-europe.com/onlineguides/nl/sc46/index.htm
Normale bedrijfssituatie:
Als beide lampjes knipperen en het papier is op gegaan tijdens afdrukken:
Leg papier in en druk op de knop met de "druppel+pagina" om de afdruktaak in het geheugen van de printer te voltooien.
Wanneer papier is vastgelopen:
Zet de printer uit en verwijder voorzichtig alle papier.
Zie de volgende pagina van de online handleiding: onderaan staat alle uitleg over beide lampjes indicaties:
http://support.epson-europe.com/onlineguides/nl/sc46/ref_g/parts_1.htm
Meer uitleg nodig ? Schrijf dan nieuwe tekst in dit bericht.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
