Cars & Trucks Logo
h
hazel russell Posted on Sep 10, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to seal canapy for leaks on 1994 ford bronco
JC Meredith
Level 2:
Sergeant:
  • Cars & Trucks Expert 168 Answers
  • Posted on Sep 10, 2018
JC Meredith
Level 2:
Sergeant:
Answers
168
Questions
Helped
42885
Points
741
4 Related Answers
Anonymous
  • 659 Answers
  • Posted on Dec 29, 2008
SOURCE: rear axle seal replacement 1994 ford bronco
It is fairly easy to do. remove rear wheels and brake drums, remove the differential cover, rotate the diff to access the diff pin bolt and remove, remove pin, push axles inward and remove c clips, slide out axles and replace seals. reverse procedure
Anonymous
  • 65 Answers
  • Posted on Aug 21, 2009
SOURCE: 1994 Ford Bronco SRS light flashes 32 code.
Probably code 32 which has to do with the egr system. Check you vacuum lines.
Anonymous
  • 474 Answers
  • Posted on Nov 07, 2009
SOURCE: Transmission fluid leaking back, 1988 Ford Bronco
your output seal on the tranny or input seal on your transfer case is bad. you have to pull your transfer case to tell. this is a pretty straight forward job. block wheels. put transfer case in neutral. drop front and rear drive lines.diconnect transfer case shift linkage. there is a short commponent connecting the trans to the transfer case. the bolt on either end face each other. remove the bolts to the transmission. the transfer case is heavier than it looks, i suggest getting help. pull back on the transfer case until it will drop down. it will pull out a bit because of the trans output shaft. replace what will probibly turn out to be the tranny output shaft seal and reassemble in reverse order.
wfservices
Wayne Fellows
  • 262 Answers
  • Posted on Apr 08, 2010
SOURCE: oil pan leak on 1994 bronco with a 5.0 liter
Oil Pan Removal
  1. Remove the bolts attaching the fan shroud (8146) to the radiator (8005) and position the fan shroud over the fan assembly.
  2. Raise vehicle.
  3. Remove exhaust manifold-to-exhaust pipe.
  4. Disconnect the oil cooler line at the left side of the radiator if equipped with an automatic transmission (7003).
  5. Remove the nuts and lockwashers attaching the engine support insulators to the chassis bracket.
  6. Drain the crankcase.
  7. Loosen transmission mounting nuts.
  8. Raise the engine (6007) and place wood blocks securely under the engine supports.
  9. Remove the oil pan attaching bolts and lower the oil pan (6675) onto the crossmember.
  10. Remove the oil pan from the vehicle.
Why does my ford bronco make a whistling noise.?
Where is the whistling noise coming from? You are driving a classic, so it could be a vacuum hose, a partially blocked radiator hose, a bad window seal, an exhaust leak...we need more information to give an educated guess.
1994 ford bronco 5.0 ltr
May be something in the fuel pump.
Check out this site
http://www.troublecodes.net/Ford/
Possible leak from my rear main seal on 87 bronco 2
The valve cover gaskets are prone to leaks and bad ones at that. Cleans the entire engine and rive it to confirm the source of the leaks or leaks.. Remember the oil runs down hill and to the rear of the engine and gets all over from leaking valve cover gaskets.
Rear differential leak?
leaking where? axle shafts? pinion seal? diff cover?
should inspect diff internals and bearings-may require overhaul not just
seal replacment. also check vent tube-if plugged will cause all seals to leak.
Oil pan leak on 1994 bronco with a 5.0 liter
Oil Pan Removal
  2. Raise vehicle.
1helpful
1helpful
Is a E4od Transmission(Ford) the same that is in my motorhome and in my f350 pickup truck,, 4 speed with OD? i have 1 1994 fleetwood bounder with a 460 ford and an e40d thansmission in it,, as well as my...
it might have just run low on fluid while driving,the front seal may not have been installed correctly,or the cooler lines or cooler might be plugged causing the trans to overheat which will cause it to leak a steady stream...for example,my 94 bronco with a e40d acted like that too when i worked it really hard pulling stumps out in the summer last year,it leaked out really bad until it cooled down,i put 20,000 miles on it since and it doesnt leak not even a drop.so mine was just overheated really bad.As for if it is the same between vehicles it is only if both trucks are a big block,and if both are 2wd.
1996 ford bronco, leaking water on left side tail gate
i would replace all the seals between the bed and the top. also the seal at the bottom of the tailgate. that should take care of any leaks unless there is a rust hole under the carpet
1995 bronco rear window leak
replace the rubber seal,but there may be more to it,the window track could be rusted causing the window not to be tight to the rubber seal
12helpful
Rear axle seal replacement 1994 ford bronco
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
