Lines on the screen (vertical/horizontal lines, bands)
Image diagram of symptom
Press the HOME button on the remote to display the TV menu screen.
When the issue occurs in the Menu screenThere may be an issue with your TV. Follow these steps to troubleshoot:
- Restart the TV and check if the issue is resolved.
- Turn off the TV and unplug the AC power cord (main lead).
- Keep the TV unplugged for 2 minutes.
- Plug in the AC power cord (main lead) and turn on the TV to check its status.
- If the above steps does not help to resolve the symptom, the product may require service. Go to Product Repair.
When the issue occurs on other than the Menu screen
There may be issues with the broadcast signal source, Cable/Satellite box, IPTV, or other devices such as a DVD player.
NOTES:
- If this issue only happen to one particular channel or broadcaster, this may be due to the broadcast signal source. Please contact your service provider for further information.
- If you experience issues when connecting a TV and an Audio/Video device via an analogue cable (composite or component cable) or HDMI cable, check the following section of this article before proceeding the steps below: Screen issues (Lines/Blurred/Odd colours) from the Audio/Video device
- Turn off any electrical or battery-operated devices that may be creating radio frequency (RF) interference.
- If using an antenna, broadcast signals are reflected by nearby mountain or surrounding tall buildings and may cause ghosting in the picture.
It is recommended to adjust the antenna direction and location.
- Try plugging the power cord into a different electrical outlet and/or surge protector.
These symptoms can occur if the electrical outlet is improperly wired or not producing the proper voltage.
If using a surge protector or extension cord, it also could be faulty.
(Back to top)
Clean the TV screen. Refer to the following FAQ.
How to care the LCD TV
If the above steps do not help to resolve the symptom, the product may require service. Go to Product Repair.
There may be issues with the TV settings, broadcast signal source, Cable/Satellite box, IPTV, or other devices such as a DVD player.
NOTE: If you experience issues when connecting a TV and an Audio/Video device via an analogue cable (composite or component cable) or HDMI cable, check the following section of this article before proceeding the steps below:
- For TVs with the Motionflow function, select Standard or Off.
- The quality obtained from DVD discs recorded on home DVD recorders often varies due to different quality settings being used on the recorders.
Picture quality from VHS tapes often appears to be significantly worse than other sources, symptoms often include grainy and watery picture.
- Reset your TV to the factory defaults. Refer to the instruction manual supplied with the product. Manuals are posted on your model support page.
(Back to top)
For other than Android TVs: Adjusting the Picture setting on my LCD TV
(Back to top)
Update the software of your TV to the latest version.
How to perform a software update.
(Back to top)
If your TV has a reset function for its picture settings, follow the instructions below to reset the settings.
Press the HOME or MENU button on the remote control.
The next steps will depend on your TV menu options:
- Select Settings- Display & Sound, Picture & Display or Display - Picture or Picture adjustments - Advanced settings - Reset.
- Select Settings- Display - Picture - Reset.
- Select Settings - System Settings -Picture - Reset.
NOTE: If your remote control has the Option button, you can reset the settings by pressing the Option button on the remote control - Picture or Picture Mode - Reset.
If the TV is connected to an active and stable Internet connection, install the latest TV software. Refer to the following FAQ.
- If your TV has a reset function for its picture settings, follow the instructions below to reset the settings.
- Press the HOME or MENU button on the remote control.
- The next steps will depend on your TV menu options:
- Select Settings - Display - Picture - Reset.
- Select Settings- System Settings - Picture - Reset.
- Check if the cable is firmly connected to the TV and the connected device and make sure it is not loose.
- Use a spare cable to replace the currently used one and see if the situation will improve.
- Use another input terminal of the TV.
- Connect your device to other input terminals of your TV.
- On the TV's supplied remote control, press the input button to switch to the input method that corresponds to the connected device and check if the situation improves.
- Connect another A/V device to your TV using the same input terminal to check whether the connected A/V device causes the issue.
- Reset your TV to the factory defaults:
Press the input button on your remote control. Make sure you have selected the correct input device (ie, coax, usb, HDMI, etc), and then make sure your cable box, usb device, HDMI device, is powered up and sending a signal. Reboot device if needed.
