Question about Compaq Computers & Internet
My Compaq isn't working - Compaq Computers & Internet
  • Compaq Master
  • 3,917 Answers
No PC stated, just the word COMPAQ , 1000s of models made
no 2 the same ,unless are. same model exactly.
not even laptop or desktop clued.
wow.
ok ill bite for zero inputs but one word, not working;
1: does it run with the big battery removed, ?
2: does the fan run.? inside, silent is a top clue is it?
3: does the screen ever show text.?
4: if yes, you get this far, does BIOS work now, the screen prompts you what to do now. hit x to enter setup(BIOS)
can you?
Posted on Sep 11, 2018
SOURCE:
My compaq presario c500 laptop keyboard isn't
only one way change the keyboard with new one. or use ans extrnal usb keyboard
Feb 02, 2013 | Computers & Internet
Why isn't Stopzilla working on my computer
Uninstall it and Clean Registry with Registry Cleaner and Install it Again it will work
Apr 14, 2012 | Compaq Computers & Internet
Compaq presario V3500 sound is not working
have you checked to make sure the sound isn't muted?
Mar 10, 2012 | Compaq Presario Notebook
Compaq D315 showing no input signal
Check if the cable between PC and the monitor is tight and re-plug it.
Try using a different monitor - to check if monitor isn't broken. If another monitor works - it's a problem with monitor. It could be just a wrong chosen input - if it's true specify please your monitor type.
Try using the monitor on a different PC - if it works then you've a problem with your Compaq D315. Probably a problem with graphics.
Dec 31, 2011 | Compaq D315 Business PC PC Desktop
Upgrade compaq armada e500
It has been a while but I think it isn't a zif but a standard low profile socket. You need a good light and check the edges to see if you can see the layers or where the cpu edges are. You should see the color differences between the plastic or the socket and the cpu. From above it will look like just a cpu but from the sides you should see the cpu overhand the socket a small bit or be flush with the edges.
The cpu has to be a M series P3 and you may need to adjust bus speeds and/or ram speed to make it work. May also have to upgrade bios as well.
Nov 17, 2011 | Compaq Armada E500 Notebook
We cant open the cam?
you need reinstall webcam driver for your oprating system, you can download it from hp.com
Jun 04, 2011 | Compaq Presario CQ56-115DX Laptop
Rejects the optical usb mouse
First, make sure there isn't any software that is needed for the mouse to work. If the mouse came with any, go ahead and install it then try to hook up the mouse again!
Jun 01, 2011 | HP Compaq nx7010 Notebook
We didnt get the drivers to install in Compaq Presario C700
If you have windows xp, goto HERE. download drivers you want and follow installation instructions. If you have windows 7 don't worry if windows 7 isn't listed. vista drivers works fine.
Please rate my solution.
Jun 01, 2011 | Compaq Presario 700 470024-192 Notebook
Presario C714NR gr983UA#ABA ALPS touchpad does not work I have updated the BIOS and uninstalled and reinstalled the drivers but it still does not work
I had a similar issue with my ASUS. Try finding a program on your computer other than the Control Panel that controls the trackpad. For instance mine is Elan Smart-Pad. Usually working with some of the configurations in the program reinitialize the trackpad. If that doesn't work make sure that it isn't turned of due to keyboard interference (hitting a button that turns the trackpad off). Hopefully that isn't the case though.
May 10, 2011 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
37 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
