Hi Check for any dust or dirt that could be stuck around any of the buttons on the camera. If the camera is under the impression another button is being pressed (because of dust dirt) then the OK button will not work. If you cannot find any button that seems to be jammed then it maybe the sensor behind the OK button has failed. We hope the suggestions helps to get the camera running again
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
