SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
SOURCE: Remote code for Sony Home Theater
Here's a link to the user manual for the remote. There's a section with codes for programming your devices.. Also, it says, if code isn't listed, there is a "code search" function on the remote..
SOURCE: rca rt2770 home theater universal remote code
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
SOURCE: need to program 311w U. remote to RTD215 home theatre
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
This works for ALL Sony Home Theater Systems
Remote Code: 21232 (a Sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Function = 44750
Mute = 33743
http://www.espares.co.uk/search/remote-controls/p/1090?utm_campaign=06-2011+unlimited+credit+1st&utm_medium=email&utm_source=emails ........ search for models of all types
