SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
SOURCE: Is a blu-ray player compatible with a rear projection tv phillip?
You need to use an HDMI connection from blu-ray player to the television. If your tv does not have an HDMI input the tv is probably to old and will not accept 1080P. If it does have an HDMI connection it should display a minimum of 1080i.
SOURCE: Contol Samsung Blu Ray BD-P1600 with Samsung remote
Compare the manufacturing dates and if remote is older, it is normal. If not, ask Samsung. Good chance
SOURCE: No picture from samsung blu-ray to samsung TV
I have a Samsung Blu Ray HT BD 1252 home cinema. This is a replacement for an identical which just stopped working after four weeks. This one is now two weeks old and will occasionally be reluctant to load a disc, recently seven attempts and and forty minutes of loading / unloading etc. It now pixelates or partial picture freeze for a second or two on every BD that we have or rent, yet plays DVDs perfectly. I have tried brand new, sealed BD discs with no luck. Any ideas before I return it to the supplier for a refund?
SOURCE: how to hook up insignia blu ray player to netflix
This model player (NS-BRDVD) is not Netflix capable. Netflix capable models are NS-BRDVD3, NS-WBRDVD, and home theater system NS-BRHTIB.
