If your Olympus VN-6200PC digital voice recorder is not turning on, even when it's not plugged into a computer, there could be a few different reasons. Here are a few things you can try to troubleshoot the problem:
It's important to keep in mind that the Olympus VN-6200PC is an older model device, which makes it harder to find replacement parts and professional repair services.
SOURCE: Bratz MP3 Player will not play downloaded music
My daughter received an ibratz mp3 player for xmas and same with us having transferred music to mp3 but when trying to play there is great nothingness! the players says the files are there but there is no authority!!
SOURCE: Sansa MP3 Won't charge or come up on computer screen!?
sometimes if the mp3 is very cold or if it has been completely drained from battery it will do that, first try using a charger that you might have for your car, or something that you can charge it from a wall outlet.
SOURCE: I have WD External Hardrive (500H1CS-00)which was
ok...go to control panel then go to add new hardware then go though the steps...should help
SOURCE: my Olympus Stylus 1050SW will not connect to my pc
Do what the pros do...use a card reader instead of your camera.
SOURCE: how to recover deleted files
You can recover deleted files with asoftech data recovery software. get the software from link below
Voice Recorder Data Recovery Software
Please be noted that your voice recorder memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
You may check out this memory card recovery tutorial also
