Ovens Logo
p
p kooistra Posted on Sep 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Miele double oven. The smaller lower oven takes about 25% longer to heat up then the larger upper oven does. What to do?
mpservices
Level 2:
Wolfpack:
An expert that has 5 followers.
  • Miele Expert 191 Answers
  • Posted on Mar 03, 2019
mpservices
Miele Expert
Level 2:
Wolfpack:
Answers
191
Questions
0
Helped
245751
Points
342
During preheat - all the element are turned on to reduce the time it takes to get to temp - if preheat is slowly - the cause is most like one of the element are bad
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Dec 27, 2006
SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Anonymous
  • Posted on Aug 06, 2009
SOURCE: Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Anonymous
  • 3 Answers
  • Posted on Nov 27, 2009
SOURCE: Dacor double oven, lower oven works fine, upper
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Anonymous
  • 43501 Answers
  • Posted on Jul 30, 2010
SOURCE: GE Double Oven JKP45BA, lower oven wont heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Anonymous
  • 130 Answers
  • Posted on Dec 15, 2010
SOURCE: convection upper oven not heating.
I Have worked on quite a few of these in the last few weeks, i have found that about 50% of these problems are caused by the control board and the other 50% caused by the thermal fuse, you can check the fuse by removing the unit from the wall and checking for continuity at the thermal fuse. If the fuse is in fact ok then it is the board that is not sending the correct amount of power to the elements. So the Power Control Board is what will need to be replaced, you can purchase both of these parts at, http://www.reliableparts.com/ by using your model number.
Please rate my solution if it was helpful to you.
If you need more in depth information or pictures on how to remove and take this machine apart, feel free to ask.
Thanks, Repairman45
Issues with both sides of Double Oven
For the smaller side, it sounds like there may be a problem with the heating element or a faulty thermostat. This can cause the oven to overheat and trip the circuit breaker. You may want to have a professional technician inspect and repair the oven.
For the larger side, it could be a problem with the heating element, the thermostat, or the control board. It's possible that the light turning off after a second indicates a fault in the control board. Again, it's best to have a professional technician diagnose and repair the issue to ensure safe and proper operation of the oven.
Feb 16, 2023 • Ovens
Whirlpool gbd307 why will The upper oven not work but the lower oven works
Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
Oven takes 20 minutes to fully heat on bake - Kenmore oven plt095-2
if its a gas model most of the time you will have a weak oven ignitor. if an electric,check to see if the bake element gets hot ,some ovens will bake with upper and lower elements so if only the upper works it will take much longer to pre-heat.good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
My HBL452 double oven is slow to heat both upper
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
heatman101
2answers
Older Whirlpool RB170PBX both ovens out
these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
heatman101
1helpful
2answers
Top Miele Ovens Experts
Paul Bade
vince
Are you a Miele Oven Expert? Answer questions, earn points and help others
