Squirrel cage fan won't come on,have red light on control panel I can see AN 1 presume FAN 1 Fan turns smoothiy by hand
SOURCE: Mod ASU24C1
If the blower is made of plastic it does not have a set screw. You most likely need a new squirrel cage. They are formed to the shaft and have a compression ring that holds them in place.
SOURCE: defective squirrel cage fan
Upon searching further, I found parts for the unit. www.appliancefactoryparts.com
Part CRCFD5303-010 Fan - $19.99
Part CRCFD3000-030 Motor - $49.99
SOURCE: Air conditioner/furnace squirrel cage fan remains running when th
probably the fan switch stuck on the fan combination control or improperly adjusted. Turn power off, remove red wire on the relay from the fan motor. Isolate so no short will happen and turn power on.The motor should not run. The fan relay could stick also. You will have to use a volt meter and see if there is voltage on the coil terminals on the fan relay. Put 1 lead to ground and touch only the terminal for the coil on the relay with the other meter lead.It should not have 120volts. If it does it is not the fan relay but possibly a limit sending power to the relay. Try that first thank you J
SOURCE: Model#CPRB09XC7 Portable A/C. The exaust fan
You can buy a new squirrel cage just take the pieces with you and the model and ser# . I deal with Bakers but there are all wholesalers of A/C parts.
