Hoses hooked up wrong.
Hello George Stewart,
The most OBVIOUS guess would be the cold water FEED is connected to the WRONG (hot water) side...
Try reversing those hoses from the wall.
Hope this helps...
Deep analysis will require a make & model number.
Carnac the Magnificent
Water connections are correct. Brand new everything. What do I do now???
If it's a samsung or LG it depends on the cycle but will put some hot out even tho set on cold
SOURCE: Whirlpool ghw9100lw2 front load washer doesn't use both hot and cold
first make sure the hoses aren't reversed hot on cold or cold on hot next turn off cold water remove the hose from the washer and check to see if the screen on the washer is clogged if not get a bucket turn on cold water and see how strong the water is then let me know what you find dont rate me till we are done
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
SOURCE: Frigidaire washer hot water only
sundsas if you have a bad temp select switch. only selecting hot/hot
SOURCE: Kenmore 90 series washer no hot water
CHeck to see if the screens in the water valve are plugged. If not the hot water side of the valve went out. Replace the water valve and it will fix both the hot and cold problem.
