SOURCE: looking for a replacement speaker for my Technics
OK. I suggest typing the model in on EBay and getting the cheapest one there is.
-K.R.
"I know what I know because I know what to do!"
SOURCE: is the tweeter a stand alone 8 ohm speaker?
yes, but it is attached to circuitry that allows only the high frequecies into it. You can replace the speaker with any 8 ohm tweeter without any difficulty, but if there is a capacitor across or in series with the speaker, make sure you put it on you new speaker the same way.
SOURCE: Morning I have a set of KEF Q 5 floor standing
I'd suspect a shorting voice coil in the woofer or a loose connection inside that vibrates and presents a wildly varying load.
Disconnect the bi-wiring jumpers and try driving each 'half' separately as a test for tripping the amp.
Try a 2.2 MF 50V cap should do the trick.
Otherwise I have seen this problem before.You just need to replace the tweeters.
The originals are no longer available but you can get some generic cone tweeter that will fit.
To be honest there is nothing special about the original tweeters so any 4-6 ohm tweeter of the same size and shape will do
Regards
John
SOURCE: I bought a used like
Hi Sir,
I am Ashish from India. Sir do you still have Jamo Center 200 Speaker? Actually I also have same speaker but it is used/second hand and have had some repairing work done on it. It's crossover also had some manipulating. Now this speaker doesn't perform very well so I need complete details of parts for Crossover/Network circuit of this awesome speaker. So can you send me image/photos of your Center 200 Crossover/Network circuit so I can identify the values of Capacitors, Registers and other parts. And also send me image of Woofers & Tweeters back panel.
Thanks
Ashish
Disassemble & reassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
