Epson driver might work. Could try a DOS text print.
http://www.fixya.com/support/t976965-problem_printing_ibm_4610_tf6
Copy of FIXYA page shown:
Question about IBM 4610 TG4 Thermal Label Printer
Problem printing with IBM 4610 TF6
I have this printer and i can't print with it on windows XP, i connected the printer with RS323 cable and it doen't communicate with the computer, i tried the IBM driver and no good.
can u plz help me.
roy
Posted by ras81 on Aug 28, 2008
ras81 Aug 28, 2008
hi
the cable is ok, because i already replaced it, the cable is new....
i think it's some kind of driver issue, but the driver on IBM site just won't work.
Furqan Sep 05, 2018
Hi
I also want drivers for my printer but there are none. How could i find them?
Bernie Role
Bernie Role
Expert
Download and use this driver instead, EPSON TM-88II Printer Driver, 4.00.
Good luck.
Posted on Aug 28, 2008
Helpful 0
Not Helpful
Comment
Flag
monk3ybidzness
monk3ybidzness
IBM Master
Use generic text driver - go for LPT (default port) then change the installed printer properties later.
get the serial settings of the printer first (bauds etc).
Helpful 0
Not Helpful
2 Comments
Flag
monk3ybidzness
monk3ybidzness Aug 28, 2008
add:
make sure that it is a 24/9 pin NULL-MODEM serial cable
monk3ybidzness
Just use the Generic Text Driver type autoexec.bat>lpt1:
or
C:\>type filename.txt>LPT1:
If that works consistently, the problem is probably in Windows.
Be sure Windows is set-up correctly with the correct printer driver and something else (another printer, FAX, etc.) is not assigned LPT1: Be sure the 710 is set as the default Windows printer. Try it on another desktop computer. If that works, try another printer on the suspect computer. I have seen cases where a baby AT motherboard was upgraded, but the printer cable/header assembly from the old motherboard was used and caused problems, but that is very rare. Also, the cable connecting to the motherboard could be backwards or loose.
Testimonial: "This page is damaged and not opening"
SOURCE: IBM POS and QuickBooks POS
wow...let's see what's up with this...so, you need drivers for that printer..what windows version you on?
SOURCE: problem printing with IBM 4610 TF6
Good luck.
SOURCE: Could some1 send me the driver for 4610 suremark
Here is the current driver for the suremark 4610;
FTP
SOURCE: After installing window 7 on
it may be that there are no drivers for windows 7, I would have a look at the manufacturers website for software from an older os (xp or vista) and try installing those in compatibility mode.
SOURCE: couldn't find audio driver for IBM thinkcentre MT-M 8327-77G for windows 7
That because this system came XP. You will need to run drivers on compatibility mode if possible.
