Have just replaced that switch again along with the lock cylinder. Have not checked wires again yet but, now my starter is getting extremely hot after 5 or 6 starts and than malfunctioning! Starter is brand new!
There is only one hot wire
in the accessories position there will be a hot wire
in the run position there will be another hot wire
in the start position there will be another hot wire
accessories runs the radio fans, cig lighter etc
the run position runs coil and all accessories
start runs coil and starter motor /relay
SOURCE: No power to ignition - ? please help! 91 amigo 2.3l
If everything is turning on, and there's power... check for 12V at the alternator. it may be out now.... or a connector came loose, or wire broke.
SOURCE: 1987 bronco will not start
Ford used alot of fuseable links, mostly around starter selenoid, look around for them and everyone you find try pulling them apart if there bad or burnt they will pull apart and there is your problem. If you don't find one burnt, than its got to be in the wire comming from the switch, heck there might be one of them fuseable links in that wire too.I never had to go that far to find a burnt one it was always around the selenoid or starter.
SOURCE: Ford f250 Truck 1987 460. Solenoid sticks once in
Most likely you need a new Ignition switch. The small "tickler" wires on your solenoid are staying on. You can disconnect the small wire from the Solenoid and then put a test light on it. Turn the Ignition to Start and see if the wire stays hot when you release the key.
Another problem you could have is the Starter has such a bad intermittent short in it, that it keeps the points welded together after the key is released from the Start position. You can get a starter Draw test done at some parts stores like Autozone or Oreillys to name a few, they do it free and on the truck.
Let me know the result please,
SOURCE: my 2001 dodge grand caravan sport won't start
DOES THE VEHICLE MAKE ANY NOISE AT ALL WHEN THE KEY IS TURNED?, IF YOU GET A "CLICK" BUT NOTHING ELSE THEN THE STARTER IS JAMMED, GET A HAMMER & GIVE THE STARTER A FEW SOLID FIRM BUT NOT OVER ZEALOUS WHACKS, MAKE SURE THE BATTERY IS FULLY CHARGED & TURN THE KEY, IF ITS ANYTHING LIKE ALL THE CARS I'VE HAD OVER THE YEARS IT WILL MAGICALLY SPRING TO LIFE - IF IN DOUBT - GIVE IT A CLOUT!!
SOURCE: fuse# 24 blows on 95 ford ranger every time turn ignition switch
There is a starter relay in the circuit in addition to the starter solenoid.
If you have replaced the components, I would guess the problem is in the harness or a connector.
