Refrigerators Logo
Frigidaire gallery temp is rising. The refrigerator is 2yrs old. Now it is make a buzzing sound. The freezer temp is set at 0 fridge is 33. Everything is defrosting....help
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
The freezer is fine steady at 0, but the refrigerator temperature keeps rising currently at 67 degrees.
Check the freezer make sure you do not have frost build up. Defrost problems choke out the air flow and if it happens the refrigerator will not cool.
Freezer too cold
Is this a model=>FGHC2342LF Sounds like the freezer=> 240597203 Thermistor may be defective??There should be one in the freezer that regulates the temp and this one may be causing the compressor to run continious and you may not be getting the correct reading from freezer. Have you seen this?
Sea Breeze
Every now and then the temp for the freezer and the fridge side rises in the 50's for a couple hours.
Defrost timer is sticking...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
2answers
We just bought a Frigidaire Gallery Refrigerator and are not sure what temperatures to set the freezer and fridge to.
The freezer should be between -5 to +5 deg.F. The refrigerator should be from 33 to 40 deg. F. but it is really a matter of preference. I set mine around 5 and 33. I like to get my ice cream out and be able to scoop it and I like my milk very cold. Start with the manufacture suggested and then adjust from there with your own preference.
2answers
Frige and freezer are not cooling!!! Help
chances are the fan motor has quit have a tech replace it if this is not the problem it could be a sealed system issue or a defrost problem
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Frigidaire gallery model plhs267Za
It sure sounds like a compressor problem to me. The buzzing sound is the compressor trying to start followed by a click which would be the overload protector tripping.
Frigidedaire
The refrigirator side of my fridge has stopped cooling, the freezer still works but the alarm went off last night and flshed" power failure" on the lettered panel. I have it set at 33 degrees but it keeps rising it is now at 61, help!
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
