K
KAMAR Posted on Sep 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony projector vpl es5 goes off after shot time of powering whats the cause
Marvin
Level 3:
Top Expert:
  • Sony Master 85,242 Answers
  • Posted on Sep 04, 2018
Marvin
Sony Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29023970
Points
266281
IS THE COOLING FAN WORKING?
5 Related Answers
stilyou
  • Posted on Feb 02, 2008
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
A
Anonymous
  • Posted on May 07, 2008
SOURCE: Sony VPL CS5 Multimedia Projector Problem
The Temp/fan light is on and is shutting down the projector what do I do
Anonymous
  • 134 Answers
  • Posted on Feb 21, 2009
SOURCE: Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
Anonymous
  • 4234 Answers
  • Posted on Apr 09, 2009
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Anonymous
  • 10594 Answers
  • Posted on Jun 01, 2009
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Green light is continuesly bling but the projector is not given the display
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
How do I fix Lamp/Cover flashing light?
There is a switch or a button that gets depressed when you close the lid of the lamp compartment. See if the plastic of the lid is broken or not hitting it right. Not screwed down right or the lamp is not seated all the way down.
Projector starts the goes off by itself.
Check the fan is working could be shutting down cause overheat
two reason
1,fan
2,lamp
I am an expert of repairing projectors for 19 years.
It is my pleasure to receive the message form you,
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
I have a Sony VPL-ES1. After I had moved my beamer from the first to the second floor it won't power on. It's connected to the power well. I've had this problem before but I would like to know...
ensure that the projector goes through the cool down cycle, for example the fans stop running, before you unplug it. Unplugging it will cause it to into power failure mode which will not allow the lamp to turn on until the bulb reaches ambient temperature. it will also extend the life of that very expensive bulb. take the extra time to let it shut down before you unplug it.
Sony projector vpl ex5 yellow display problem
try replacing the bul/lamp.
warning! $200 part http://www.amazon.com/Projector-LMP-E190-VPL-ES5-VPL-EX5-VPL-EX50/dp/B003ISW2KM
1helpful
Hi My Sony VPL ES5 SWITCHES OFF THE LAMP AFTER 2 MINUTE
hi your projector probaly has done around 2122 hrs on the bulb just reset the lamp timer and you should be good to go ps this worked for me (answer yes to replace bulb and clean filter then press ok pps might be a good idea to start saving up for a replacement bulb hope this helps cheers !!!
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
