SOURCE: Casio fr-2650 plus calculator
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
SOURCE: how to calculate log value in calculator with different base value
In any scientific calculator log2(n) can be calculated with either ln or log function as
follows
Log2(n)= ln(n) / ln(2)
Or
Log2(n)=log(n) / log(2)
both will give nearly the same answers
SOURCE: m mod n in Casio fx991MS
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
SOURCE: FX-55 Calculator: how do I clear my casio scientific calculator from...
press the "MODE" button 3 times and then press 3 ..., now this is normal mode
SOURCE: solve a matrix of complex
Well, the equation is Ax=b and we want so solve for x
There are several ways of entering the data, but this is one way
Code:
A=[15+35i 29+1i; 46+13i 62+3i]
b=[0;0]
x=A\b
which has the trivial solution x=[0;0] (the ";" means "next row", a space next column.)
To input a matrix use APPs then Data/Matrix Editor then New. Then change Data to Matrix. Put in the name such as "AA" in the variable field. Then enter row and column dimensions. Then edit as a spread sheet. Use F6(util) to delete a column or row. To manipulate matrices, exit the matrix application, then go to MATH then Matrix. Notice that J(RowOpps) is available.
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this answer. Happy holidays!
