WT38UK commercial dishwasher needs reprograming/wash cycle too short an no rinse cycle?
Hi Can someone please help me with my Electrolux WT38UK commercial dishwasher. It appears to have reset its nself to factory settings so doesn't run a proper wash cycle only a few seconds and doesn't always start a cylce?? Help i'm drowning in dishes.......
Rinse aid dispenser can receive a maximum level of 140 ml rinse agent. Consumption rinse agent could be per wash cycle of 2 to 7 ml depending on the settings.
Thus 140 ml is enough for 20-70 wash cycles, depending on the degree of adjustment.
I see that your Electrolux dishwasher starts cycle on low rinse. This typically indicates your dishwasher has low rinse aid. The RINISING AGENT LOW light, typically located near the Rinse Only Pad, comes on at the end of cleaning cycle when the rinse agent reservoir is low. The light will remain on through 5 successive cycles or until the reservoir is filled. Also, using rinse aid will enhance dryer performance and reduces water sports and filming. Hope this helps!
Hi I think I’ve got the same problem that the overflow plastic tray didn’t move down due to dirt. See pic. Anybody an idea how to open/ remove and clean this tray on Electrolux dishwasher?
This is a siphoning problem. Please clean out the dispenser cup(s) as much as you can and try again. You may need to clean the unit and run vinegar through instead of bleach to unclog any small components.
Hi Open the door.
Within 3 seconds press the following sequence --Try pressing normal wash,
heated dry, normal wash, heated dry, normal wash, heated dry three times within
6 seconds and then press cancel to reset the dishwasher. If that doesn't help
then try pressing Saini
Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air
Dry, Saini
Rinse, Air Dry, Saini
Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door
and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally.
If the light is still blinking try and reset the power to the dishwasher and
try again. If still the light is blinking then check for the connections on the
keypad, it may be due to moisture or shorted connections on keypad. Hope this
helps... Please post back if you need more information. Daniel
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
First off, the temp adjustment can only be made by a trained service tech, since the dishwasher will need to be reprogrammed to allow for a lower temperature in the rinse cycle but still have the higher temp needed in the wash cycle. Also, since any change in the water temp settings will require a longer wash and rinse cycle to be programmed into the unit.
Of course, you could simply lower the water temp on the water heater that supplies water to this unit, but you'd have lower temp water elsewhere and likely get cited at the next heatlh department inspection on that issue.
Since this is a commercial dishwasher, you might want to reconsider lowering the temp, since health codes and standards for commercial establishments require a MINIMUM water temperarture of 185 degrees F (85 degrees C) for proper operation and to get all the crud off the dishes, etc.
Note, the manufacturer sets these units to the higher temp, 203 degree F (95 degree C) knowing that the water will cool down quickly once the wash cycle starts and the water contacts the dishes, etc. That is also why these units have a added heater element, to help keep the water at the correct temperature needed to both clean AND sanitize the dishes, according to established health standards.
If you really want to change the water temp settings, contact your Hobart service rep and explain the reason you want it lower and see what they say.
Hope you found this very helpful and best regards!
Ther have been a lot of complaints about the drying performance of these machines. One solution suggested by Electrolux is to use the "anti bacterial" wash mode, as this is a higher temperature wash, therefore dishes dry better. If you are using Eco wash or Quick wash, drying performance is not very good- Electrolux recommend leaving door ajar at end of cycle to improve drying. Also, ensure your Rinse Aid compartment is topped up, as Rinse Aid greatly improves drying performance.
-Please note: these dishwashers will not dry plastics and other items that do not hold the heat very well!!
-Also, you should be able to hear the drying fan running at the end of cycle- if not, then you may have faulty fan (uncommon), or control board (more common).
Good luck!!
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
What is the model of the dishwasher?
Open the door and look down the right hand side for a sticker and repost please.
As a rule number 3 is a normal wash :D
