SOURCE: Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
SOURCE: Amana Bottom Freezer control knob
http://amana.com
go here and scroll to the bottom of the page and click on "sitemap"
and you will find help information.
SOURCE: Amana Refrigerator
Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
SOURCE: Bottom freezer on Amana refrigerator is too warm,
is there frost building up in the back of the freezer wall?mike
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
