SOURCE: CANON IR 400 COPIER - ERROR - E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
SOURCE: My Canon ImageRunner gives me a message of
Buy the optinal equipement which can be a fax card or a universal send kit
SOURCE: i want service manualto canon ir-2016 ir-2318
haloo try thy link , i canot upload the manual
http://www.girlshare.ro/490546.1
SOURCE: ir 2318 shows "out of toner,whilst there is new
open the front cover .there u will see a blue handle .turn it clock wise while pressing the handle on it, u remove that by pulling ad replace the same with a new one in the same oppsite manner
SOURCE: cannon ir 1023 will not scan in windows 7 64bit
For the scanning you have to use the USB port and load the Tool Box 4.9 scanning software on the CD or from the Canon site. If you have commercial scanning software you will have to use the Scan Gear software as an interface between the scanning software and the copier.. Good Luck.
