Concerned that my machine is getting ready to fail. Espresso some times runs real slow, occasionally 'frother' does not receive steam injection. Anticipating the need to repair it. Is there any repair service that works on/repairs these machines?
SOURCE: briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
SOURCE: Kitchenaid Espresso maker no longer dispenses hot water from frother
by frother you mean it puts out steam ? if yes then I need to know how long you hold down the button and have you checked the hose in back to see if it has cracks or is kinked?
SOURCE: AEG ESPRESSO MACHINE
With the machine cold (or hot if you have the right implement and can keep your hands away from the steam) I would try to insert something like a pin or a small length of bicycle brake cable up the frother tube and see if you can free what probably is a plug of solid mik in the end of the frother. Sounds like a blockage, it may suddenly blast out steam if you free it and you have the valve open so watch out. If it's not that then I would take the valve apart, especially if the machine is making the right noises. I'm not farmiliar with AEG machines though.
SOURCE: KPES100PM Espresso Machine - will not make espresso
While I am familiar with Kitchenaid espresso makers, I am not familiar with this problem. I would suggest calling Kitchenaid Customer Service, as you will have options under your Pro Line warranty. Their toll-free telephone number is:
1.800.541.6390.
Solis Master 5000 Espresso Machine - YouTube
? 9:49
www.youtube.com/watch?v=MjBmlQXElag
Sep 2, 2010 - Uploaded by Day Tooley
I have been enjoying the Solis Master 5000 for a year. It's time to ... I haven't been able to find an actual user manual online...for some reason.
