Question about Polaroid Televison & Video
Where can i get a replacement battery for POLAROId PDM-0743
    Sergeant:
  • 445 Answers
SOURCE:
tech48
  • 624 Answers
SOURCE: ac adapter sometimes works for a few seconds not at all
It most likely has some broken solder connections on the jack. Unless you have soldering equipment there is nothing you can do yourself except to take it to a repair center. If you tell them that the A/C adaptor jack has some broken connections that need to be resoldered, they may give you a break on the normal repair cost since this is not a big job. It just requires the right tools. If you have the soldering equipment you can take it apart and resolder those connections on the jack yourself.
Posted on Dec 04, 2008
  • 65 Answers
SOURCE: When I put in a CD or DVD on my Polaroid PDM-0743
If cleaning the lens on the laser does not solve the problem, then you will need a new laser or optical pickup. You may as well buy a new unit.
Posted on Aug 02, 2009
  • 155 Answers
SOURCE: I have a portable 7
First thing-- try a disc drive cleaner (available at electronics stores) OR if you can see the laser lens when you open the tray you can clean it with a Que-tip and some rubbing alcohol.
If that doesn't work, let me know.
Posted on Mar 26, 2010
gopakumarg43
  • 76046 Answers
SOURCE: Where can I find a
Hello
Get inot the websites or 'Ebay' or 'Alibaba' and search with your battery model number. They will have it, and send you by E-payment. OK
Posted on Jun 30, 2011
  • 1755 Answers
SOURCE: pdm-0743
Hi, More info is needed.
Posted on Jul 13, 2011
Shows all disc as bad
if you have a dvd lens cleaner tried to clean it first. if still no disc error, look for the spindle motor if it is rotating while you are playing with a disc. if not, check for motor worn out at this time you will need to remove the cover to access the internal part.
Nov 02, 2012 | Polaroid PDM-0743 Portable DVD Player
Pdm-0743
Jul 13, 2011 | Polaroid 7'' Portable DVD Player
Instructions book
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Jul 13, 2011 | Polaroid PDM-0743 Portable DVD Player
Where can I find a replacement battery for a Polaroid PDM-0714?
Hello
Jun 30, 2011 | Polaroid PDM-0714 Portable DVD Player
Dvd player will not play any dvd, shows bad disk
hi,
ur dvds laser pickup unit have some problem. first of all check the spindle motor which rotate the cd. there is chance to motor become faulty. when u insert dvd the motor will not rotate it the required rpm. if its ok then laser pickup unit have to be replaced
ok
Jan 01, 2011 | Polaroid PDM-0743 Portable DVD Player
I have a portable 7" dvd player PDM-0743. When I insert discs it says "bad disc". I have tried several discs and it says the same.
Mar 26, 2010 | Polaroid 7'' Portable DVD Player
When I put in a CD or DVD on my Polaroid PDM-0743 star loading but after a while have a error. DAD DISC or NO DISC, any ideas what should be the prolem?
Aug 02, 2009 | Polaroid PDM-0743 Portable DVD Player
DVD Player that repeatedly says NO DISC for Polaroid PDM-0752
either needs to be clean or the REGION needs to be set up to 1 or ALL , LETS TRY WITH cleaning the OPTICAL LENS with a dry Q tip , gently rub a few strokes at the lens , and give it a try, if NOT then try to set the REGION to 1 or all, if still not reading the disc , then have to replace the optical lens, good luck , AJ
May 28, 2009 | Polaroid PDM-0742 Portable DVD Player
Shows bad dics all the time
I have finally fixed ya you BAD DISC error message on the Polaroid PDM-0743 ok, listen carefully, first try cleaning the eye lens in the dvd player with a Que Tip with "distilled water" or with "rubbing alcohol" and then let dry, put movie in, turn power on, and it MIGHT WORK? but my guess it will still say BAD DISC, so if that happends it's take apart time you will only need one tool <p><img src="http://img.photobucket.com/albums/v609/goodold56/Tools.jpg"></p> Take out the battery and Flip the unit over where the DVD players LCD SREEN is sitting on your lap you should find alot of black screws just un install the screws on the back <p><img src="http://img.photobucket.com/albums/v609/goodold56/backofplayer.jpg"></p> but wait take this sticker off too. <p><img src="http://img.photobucket.com/albums/v609/goodold56/sideofpalyer.jpg"></p> and after that <p><img src="http://img.photobucket.com/albums/v609/goodold56/laserlensscrew.jpg"></p>
Mar 30, 2009 | Polaroid PDM-0743 Portable DVD Player
Off and on the players says bad disc
I turn it on and all i get is a blue screen. It will loading disc and say bad disc.
Aug 02, 2008 | Polaroid PDM-0743 Portable DVD Player
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
