You can buy an aftermarket radio harness adapter for your Navigator from ebay quite cheaply. I would not recommend butchering the factory wiring to install a replacement head unit. I found this one (will work as long as your Lincoln wasn't fitted with SATNAV) -
Lincoln Radio WIRE HARNESS INSTALL STEREO PLUG 2003 09 eBay
SOURCE: cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
SOURCE: wiring colors from head to amp
Check here, this guide might have what you need.
http://www.installdr.com/InstallDocs/Jeep/PDF/533013.pdf
SOURCE: can't find the amp in my ford explorer
The amp should be located cargo area on the drivers side. You will need to remove the panel to get to it.
SOURCE: need color code diagram for factory 8 speaker
On my 99 4 door the factory amp is powered by a hot pink wire in the truck harness. I hooked the cont. power for a motorized ant. to it and all 4 speakers work. I'm going to check today to see if they work correctly because I found this out late last night and only had it on for a few minutes. I've read that there is a harness for this that apparently you have to specifically ask for at a car audio shop. hope this helps.
SOURCE: need to know the color of each speaker wire on the speaker factory harness
1995 Ford Explorer Car Stereo Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
