Cars & Trucks Logo
Jezika Komplakated Posted on Sep 03, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to know 98 zx2 radio wiring diagram - Cars & Trucks
Colin Stickland
Level 3:
  • Cars & Trucks Master 22,516 Answers
  • Posted on Sep 03, 2018
Colin Stickland
Level 3:
Answers
22516
Questions
Helped
6999039
Points
66324
Use a multimeter to locate and then connect accordingly .12v permanent feed to memory wire on radio and switchable 12v feed to fuse feed .blue wire is normally electric aerial .Just look and you should see the wires ,speakers will have the two wires the same colour but one of the two will have a stripe in the colour .
  • Jezika Komplakated Sep 03, 2018
    Black
    White w/ orange stripe
    Green w/ white dashes
    Blue w/ red stripe
    Blue w/ black stripe
    Red w/ black stripe
    Someone cut the factory side of the harness please help I already figured out the speakers
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Feb 03, 2009
SOURCE: Need diagram for routing of
Go on the Dayco belts web site. They make serpentine belts and a pretty good data base of belt diagrams for any vehicle they make a belt for.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Mar 19, 2009
SOURCE: Wiring Diagram
Ok from the manual. please rate this info
Molson02536
Harvey N Tawatao
  • 3854 Answers
  • Posted on Jun 25, 2009
SOURCE: need the radio wiring diagram for expedition 98
http://www.installdr.com/Harnesses/Ford-Wiring.pdf hope this link helps. Good luck. Keep me posted.
Anonymous
  • Posted on Sep 11, 2009
SOURCE: belt routing diagram 98 zx2 2.0
1) Start with the alternator.
2) Forward to the smooth idler
3) Forward to power steering
4) Down to A/C compressor
5) Back to crank pulley
6) Forward around tensioner
7) Back glancing off of water pump
8) Back glancing off of ribbed idler
9) Up around alternator (where you started)
c17hydro
Greg Bernett
  • 2993 Answers
  • Posted on Feb 14, 2010
SOURCE: spark plug wiring diagram for 98 tahoe
You didn't post your engine size so please pick the applicable diagram:
1996-98 4.3L Engines Firing Order: 1-6-5-4-3-2Distributor Rotation: Clockwise
1996-98 5.0L, 5.7L and 7.4L Engines Firing Order: 1-8-4-3-6-5-7-2Distributor Rotation: Clockwise
4.3L Engines Firing order: 1-6-5-4-3-2 Distributor rotation: Clockwise
4.8L, 5.3L and 6.0L Engines Firing order: 1-8-7-2-6-5-4-3 Distributorless ignition system (one coil on each cylinder)
5.0L, 5.7L and 7.4L Engines Firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
2003 Ford Escort ZX2 stereo wiring diagram please?
2003 Ford Escort ZX2 Audio Wiring Chart
MODIFIEDLIFE https://www.modifiedlife.com > 2003-ford-escort-zx2-...
Our 2003 Ford Escort ZX2 radio wiring diagram shows you all the radio wire colors and what they do. Table of Contents. 2003 Ford Escort ZX2 Radio Wiring Diagram ...
2000 Ford Escort ZX2 Car Stereo Wire Colors and Locations
The12Volt https://www.the12volt.com > installbay > stereodetail
2000 Ford Escort ZX2 Stereo Wiring ; Antenna Trigger, n/a ; Antenna, Right Rear ; Front Speakers, 5 1/4" Doors ; Left Front (+), Purple ; Left Front (-), Blue/Orange.
Ford Escort Stereo Wiring Diagram
Pro Street Online https://my.prostreetonline.com > 2016/03/10 > ford-es...
Mar 10, 2016 - The Ford Escort was available through three generations, and today I'll be showing you our Escort stereo wiring schematic from 1980-2003.
2answers
Serpentine belt diagram 2002 Ford escort zx2
The picture is for a zetec. Let me know if wrong diagram?
2answers
I have a 2002 Ford Escort zx2 I replace the battery 3 days ago and my radio will still not turn on... any suggestions??
Check the radio fuse in the fuse box. Maybe its blown, otherwise it may be a failure of wiring or the radio itself. Check the wiring before removing the radio to check the back of it. Check the wiring in the attached link:
2002 Ford Escort ZX2 Car Radio Stereo Audio Wiring Diagram
Need wiring diagram for relay for fog lights on 2003 zx2
its listed under escort zx2 chassis electrical wiring diagrams in autozone library,i just looked it up.
I need a belt diagram for a 98 Ford Escort ZX2
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
Thanks!
http://www.2carpros.com/car_repair_information/year/1998/make/ford/model/escort/1998_ford_escort_drive_belt_routing_diagram.htm
1helpful
2answers
Need diagram to install serpentine belt
2001 ford escort zx2 belt routing diagram
1helpful
I need to replace the drive belt on my 98 Ford Escort ZX2 manual transmission and need a diagram and to know where the tensioner is located. It is a single belt.
There are 3 possbile diagrams, depending on whether it's equipped with AC and engine type. The 3 are listed below. Thank you for using Fixya and please remember to return to rate this answer.
Greg
98 Escort Drive Belt Air #1
98 Escort Drive Belt Air #2
98 Escort Drive Belt no Air
11helpful
Belt routing diagram 98 zx2 2.0
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
