SOURCE: E000225 & e000019 error code
The error code E0019 is the waste toner bottle is full you need to empity out the waste toner bottle and make sure the neck of the bottle is totaly clean and clear, a sensor reads dirt on the neck that the bottle is full. To clear that code after cleaning the waste toner, turn the main power switch off on the right side of the copier. The waste toner bottle is on the left hand side toward the rear of the copier and is held in with one screw. The E00225 deals with the scanning lamp. you will have to replace the lamp and the lamp PCB as a set to solve that problem. Good Luck...
SOURCE: ir 3300
i have an IR 3300 (used) i have given TCP/IP correct with machine and PC also. ping command is working properly and IR Machine also response from the host and also i'm success output (Printout) but can't scanning. I have scangear also tried but the messeage appear "the spacified IP address is invalid or scanner is not connected to the specified IP" but my IP address is correct. (both side) i know that after this my Machine will be online from System button but there is no software. i cant solve my problem
how can i connect my Machine from PC
SOURCE: Canon IR-3300, error 354
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory , if you are try to change the counter pcb to get rid of high meter reading this error is possible, this a security measure of canon to prevent meter tampering
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
