Whirlpool no longer sells water heaters ... but in the past, they sold the AO Smith brand flue damper and atmospheric heaters ... both use different Honeywell gas controls.
If you have some fundamental electrical training/experience.
Undervoltage 1902
ALARM
Fault is displayed when both zero crosses are missing from the controller's input for 1.5 seconds or more. Could be a faulty excitation winding, zero cross circuit, loose wiring, or field boost hardware problem. Same applies here, v1.12 or later firmware should be installed.
Hi Benny:
I don't know what the code means, but I'd:
- fill the oil to the proper level
- install the cap
- disconnect and re-connect the battery to see if I can make the code go away
- Try using the generator
We use similar products in our warehouse as well, and usually there is a config file within these that the codes are programmed in, and shouldn't be deleted if it loses power. However, I would contact the original manufacturer for complete details on this item.
