First I'm not a louisiana Grill representative.
* Check your warranty. call for support.
*** Following is for information only.***
* Any item that can burn will burn if it has; Fuel, Air, Space to burn.
* Pellets catching flame means all three items are available.
* Check your "Flame chamber" Is it open for full burn or searing position? (full open where you can see the pellets and lots of air can get to it? This air will allow the pellets to burn quickly.); https://www.youtube.com/watch?v=1R_eloeM0Fw
* Check if your cover to grill is fairly air tight as when it was new. Though the burn chamber is what keeps most of the air out. The lid also helps keep drafts from causing flare ups. Smoking requires "smothering" the fire. Keeping the air out.
* Check if your electrical power (extension cord) is okay.
* Check if your meat probe is still working and calibrated. If this probe (wires) are broken then the feed will think the meat is cold (or hot) and over feed (under feed) the burn kiln.
* Check with your vendor for advice.
Aloha, ukeboy57
Additional information;
* https://www.youtube.com/watch?v=YNXuW2YeMoY
SOURCE: traeger junior 2 weeks old dosen't seem to make
Take and unplug your electrical cord and then take the bottom grate that covers your motors and components off. The are 4 small screws and then it should drop down. Look to see that there are not any wires hitting your fan motors. You can just reach up there and move them around if they are. Some Treagers seem to have some noise until you use them a little. They have a 3 year warrenty, so if the wires are not hitting the fan blades, I would use it and see what happens.
SOURCE: when I turn grill on it throws the breaker
Try a different outlet, maybe the breaker is bad with the one you are using. The hot rod could be bad as this seems to be a problem with Treager grills. They should be under warrenty so call and have one sent to you. To check the hot rod, unplug your grill and the reach up from the bottom and unplug the purple wire. Plug the grill back in and see if it will start. If it does, it is the hot rod.
SOURCE: Quadra-Fire Pellet stove-Pellet pot fills.
Sounds lie an Ignition Box problem. Quadra Fire recently redesigned their Ignition Boxes, so your may wan to replace yours. In addition, contact Quadra Fire Technical Service and speak to Steve Tate. He's a real guru when it comes to this problem. Don't settle for anyone else.
Hope this helps solve your problem.
Testimonial: "Thank you...don't know who Steve Tate is but will definitely look into Ignition Box replacement."
