SOURCE: How do you scan to PDF on a Konica Minolta Bizhub
Touch [Fax/Scan] to display the initial screen for fax/scan operations.
Touch [Scan Settings] to specify detailed settings for scanning
In Scan Settings >File Type , select elect the file type for saving the scan data. The following file types are available (PDF,Compact PDF, TIFF, JPEG, XPS, Compact XPS).
Touch [PDF] or [Compact PDF]
In addition, the grouping of the saved data (single PDF or multi-page PDF) and the encryption settings (encryption level, password, document permissions, and other detail settings) can be specified.
You should check the user’s manual for images and more detailed info on how to operate the machine.
You can download it from here:
http://download6.konicaminolta.eu/konmin/servlet/KonMinMaster;jsessionid=9D04D81DD26189D21B3B2B8B32D2B06F.node02?path=../search.jsp&mode=show&document=32545
SOURCE: Error code C-3505 Konica Minolta Bizub C6500
This is a fuser code, which needs reset by your service provider in service modes, let me
SOURCE: Konica Minolta Pagepro 1350 page count or Print Config sheet?
please go printer utilty option on your pc then you can print a testpage
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
SOURCE: My Konica Minolta MC2300DL will not print. It is
You can change the 2300's menu setting to ignore empty toner cartridges and keep printing. There are 2 steps:
Step 1:
Press Menu/Select, then "right arrow" until you see ENGINE. Press Menu/Select again and then "right arrow" until you see TONER EMPTY. Press Menu/Select and you'll see STOP. Press "right arrow" once to change to CONTINUE. Press Menu/Select.
Step 2:
Press "right arrow" until you see AUTO CONTINUE. If set to ON, press the "Cancel" button and you're ready to print. If set to OFF, press Menu/Select, then right arrow to change to ON, then Menu/Select to enter. It will say "ON IS SELECTED." Then press the "Cancel" button and you're ready to print.
Hi kass kass, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? please explain what you said makes no sense
