Philco (R) Classic Turntable CD Shelf System Logo
Dan Hanson Posted on Sep 02, 2018
Ive got a philco 37-602. I replaced the pilot light socket and replaced the bulb. It shines, then dims to nothing after about 10 seconds. What next? Thanks!
Lights dim
Was any of the brake light bulbs changed recently, the wrong type of bulb may be used causing a short in the socket, and making the rest of the brake and signal circuit malfunction. I no bulbs were recently replaced, start with checking for corrosion in each bulb socket, signal and brake bulb sockets. Let us know what you find
tip
Brake Lights Dull or Flickering - All Cars
Dull or Dim Brake Light Repair: If your car has a dull or dim brake light it is dangerous to you and other drivers. A dim brake light is a mystery to most people because the bulb is working, just not correctly. First confirm a new and correct brake light bulb has been installed. Next, turn the ignition key to the "on" position and have a helper depress the brake pedal. With the bulb installed touch a grounded test light to the outer bulb holder ring. If the bulb brightness changes the bulb socket ground has high resistance and needs to be repaired or replaced.
Flickering Brake Light Bulb Repair: A flickering brake light bulb can be very distracting and annoying. A brake light flickers because the power or ground is being obstructed momentarily. The most common cause for this condition is a loose fitting bulb socket. To check for this condition remove the brake light bulb in question, while a helper hold their foot on the brake pedal move the bulb around slightly in the socket. If the bulb flickers replace or repair the bulb socket as needed to regain proper brake light bulb operation. If the brake light bulb socket tests ok wiggle the brake light fuse and wiring at the brake light bulb socket, brake light switch and turn signal switch (American cars). If the brake light bulb flickers repair the component or wiring as needed.
Preferred Procedure: Always replace brake light bulbs with manufacturers recommend replacement bulbs. If you cannot find the correct replacement bulb part number consult an auto parts store for additional manufacturer information.
Common Problems
When brake light bulbs are replaced with the incorrect bulb causing no or dim brake light operation
If the brake lights stay on continuously it could mean the brake light switch has failed or an adjustment is needed.
5answers
Tail light not working brake works
Justo change the socket or put some grease for bulbs
1998 Honda CBR 1100 XX Super blackbird headlights not working
Sounds as if the switch is worn or faulty , find a new or second hand switch to change it over with .
Left front headlamp is dim when turned on.
sounds like a ground problem. check the socket also for rust.
2answers
I just bought new headlight bulbs but one light is way brighter then the other, my left is brighter then the right and stays dim even when i turn on the night lights. whats the issue?
dear,
There is the issue with the wattage of bulb you have got for the vehcicle.
And also due to a new bulb it shines brighter then the old one.
get the old one also repaced to get the equal brightness
thanx
1helpful
I have a 2003 volvo s60..im getting an error message for bulb failure on the left turn signal..ive replaced every bulb and just noticed that the front bulb is glowing dim. any suggestions?
the bulb sockets go bad all the time on volvos. look at the bulb base were it slips into the socket you will see a very small little black maek on the wire on the bulb. get a new socket at volvo. they just plug in
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Larry
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
