You need two things. A USB lead to connect to your camera and software installed on your computer to recognise your camera is connected to it via the USB lead. The software and USB lead should have come with the camera. The software will be on a CD or DVD. If it did not then you need to download the software from the Sony website and then install it on your computer. Depending on your computer, ensure you download the correct type. It will either be for a MAC IOS or Windows PC.
SOURCE: Windows 98 Driver required for sony cyber-shot dsc-w35
Windows 98 is not officially supported by Sony for the DSC-W35. You can find hacked versions on the web but they may not be stable. You can find a list of supported Operating Systems here at the Sony website. http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCW35&LOC=3
I would suggest trying to use the Windows ME drivers. Windows ME was based on Windows 98 so the drivers for most applications are virtually identical. I have used 8 different drivers from other vendors in situations like this and it worked out fine. However, please be aware that since it is not officially supported it can cause interoperability options with your Windows 98 system.
This is the best suggestion I have. By no means should you get Windows ME, it was one of the worst versions of Windows released. Lots of bugs and there are less drivers for this operating system than your Windows 98.
SOURCE: Sony Cyber-Shot DSC-N1 - download photos from camera onto computer
You need to go to MENU, roll down to SET UP
if you roll down you would see at top
"Camera1", "Camera2" and "Memory Stick"
go to Memory Stick and roll down to COPY
go to ALBUM...
and then she ask you...All data in Album will be copied. Ready? touch OK ....
Now you create a folder with all the photos in the memory and you can download it.
I hope this help you...Liz Annette PR
SOURCE: Sony Cyber-Shot DSC-P32 won't connect to computer
I think you have a wrong setting, go into the menu and go through it and it says USB connect or something to do with PAL/NTSB i don't have one in my hand.
