Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
https://homenol.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done./
SOURCE: closed captioning
I am sorry you don't. You will need the original remote. I have enclosed a link where you can see the original remote and order one if you want to. If you see the picture, there is a caption button on the remote to turn on and off the closed captions Good Luck. Here is the link http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS24424&brand_pn=SANYO_DS24424&mode=large&uid=11872683567810
SOURCE: rca system link 8av remote How do I turn off closed caption??
CC is usually turned off by selecting an inactive choice,i.e.
If CC1 is on, then try CC2......
Further info ? Please provide Model # of TV.......................T.
SOURCE: Sony 46" XBR2 Cannot turn off closed caption
With TV on, turn off DVR and hit menu on DVR remote - you can disable CC from there. Worked for us - got the idea from another fixya post.
SOURCE: how to turn off closed captioning without orginal remote?
well if it has a menu option go into menu then set up and change cc okay if does not have menu button try to find universal remote w/ menu option and try to change okay
SOURCE: closed captions will not work thru my tv remote
I hope this was resolved but this is a dish page and I am unable to answer Comcast issues.
