SOURCE: Filter broke off in the holder
I have recently had to remove one that the end cap had broken off but I don't think you will be able to get this one out. You will need to replace the filter housing. It's not hard to do. You just need to get the part, pull the 2 screws holding it in along with the wire off to the left side, remove the water hoses and install the new housing.
SOURCE: replace light bulb holder on refrigerator side
This is what your looking for..........
http://www.partselect.com/MultiModels.aspx?ModelNum=GS6NBEXR&searchTerm=img_1HOOJ3RJ&RefineSearch=0&imgMfg=Whirlpool&Page=2
SOURCE: how do u replace water filter on samsung
The water filter in the extra space behind the vegetable Bin.
1) As shown, the fixed cap separates from the refrigerator by rotating
it counterclockwise.
Remove the water filter from the box and put a month indicator
sticker on the filter as shown on the next page.
2) The water filter should be replaced every six months, so if the filter
was installed in March (for example), put on the "SEP" sticker
to remind you to change the filter.
3) Remove the protective cap, then position and insert the
filter as shown.
4) Slowly turn the water filter clockwise 90º to align
the indication mark on the cover, locking the filter in position.
Or go here bottom of page 24 top of 25.
http://www.azmanual.com/download/21949/5478c9cd79f4e04b6a2f6e2b4ab9f513/
Please rate 4 thumba for the free answer.
SOURCE: We had a new Samsung RS267TDWP side-by-side frig
It takes approx. 24 hours for a freezer to reach optimal temperature and to stabilize, only because in a 24 hour period the machine will shut off about three times for it's defrost cycle, but like you listed, freezing temperature will be reached in about 6 hours.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
