Because,I set a wrong time,date on my new Leica camera,,,
SOURCE: set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
SOURCE: date changes wrong time
thats because analog watches don't know the difference between AM/PM. First reset the time, moving the hour and minute hands another 12 hours will let you know exactly what mode its in (am/pm) first allowing you to set the date correctly.
SOURCE: Casio EXZ75 Camera
Your problem does not lye on any memory card. it is because the internal battery that helps the cmos "cameras internal memory" hold its settings has gone out and needs tobe replaced. all you need is 2 1.5 volt hearing aid batteries stacked and taped +-+- and soldiered in place of the old cmos battery. witch is located on the front side bottom close to the bottom left of the lens. and placed next to the speaker. get some small batteries to do this het smaller the better for placement location.Hope this helps I have done this to a few camera's and it works fine.
SOURCE: lost usb computer/camera connection for leica d - lux 2
There's several standard configurations for USB cables, and chances are, you need one of these standards.
Take your camera to a local computer store, or even a Best Buy, and they'll SHOULD be able to find a cable with the appropriate end to fit your camera. Chances are the computer end is a standard full size USB connector.
SOURCE: Can't reset Date & Time
What you have to do is go to the icon with the spanner (as shown above) and keep tabbing down. There are more options than just the ones you see in the screen (not just High Power , Auto, Set Tag, On), keep going down and it will show you the other options. You will see the date change icon about 7 or 8 down.
