SOURCE: DirecTV Remote Control of Polaroid TLA-01511C
These worked for me
Polaroid
10765, 10865, 11262, 11276,
11314, 11316, 11326, 11327,
11328, 11341, 11498, 11523,
11991, 11992
SOURCE: Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
SOURCE: POLAROID 1511-TLXB LCD TV Remote Code for Verizon FiOS STB
I posted that as a point of information. I noted from searches that other people were having remote code problems w/that TV set. Code 0205 worked for me.
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Factory Mode Procedure
1.Power on TV.
2.Press volume up and channel up buttons on the TV simultaneously and release.
3.Power off TV with remote or power button to exit.
If this doesn't work you can get a polaroid replacement remote here:
http://www.discount-merchant.com/Polaroid-RC-201-Remote-Control-p/remote-9039.htm
