GO here and down load the user manual
https://www.samsung.com/us/support/owners/product/2018-qled-tv-q9fn-series
SOURCE: Need to update my graphics card
anything modern should be able to handle that resolution. should say on the package what the max reso is and if its over what you need id say its a safe bet. That card your using is really old and out dated. i dont even think you can by cards that have less then 128mb of vram on them anymore.. hope this helps, good luck.
SOURCE: Black box in the middle of my mitsubishi tv
This is a common problem, some how you have the closed caption on and turned to the text mode. So to fix this scoll through the tv's menu and find the closed caption and tur it back off
SOURCE: very poor resolution
go to ebay and you can get the zenith remote for that tv for 20.00 dollars because i got a new one from ebay
SOURCE: Screen Resolution Problems with Samsung 50" DLP
You may have already done this, but check to see if you can change the screen size in the set-top-box settings and set this to widescreen 16:9 to match the tv. You may also have 14:9 as an option too. Also, check your video output settings, this can be changed between RGB, Composite, PAL or NTSC.
Let me know if that does or doesn't solve the problem
Tim
SOURCE: New RC64 will NOT setup with R16-500 Direct TV DVR
The Direct TV remote control I'm currently using is a RC64RB I guess the RB stands for radio broadcast? I learned from researching on the internet that the Direct TV DVR receiver has a different setting for each type of remote. The "RB" remote (the one I'm currently using) has an FCC sticker on the back. Direct TV sent me the wrong type of remote control. AND they have wasted hours of my time. The DT technician that I sought answers from is an idiot!!
